So just done ffp on my neo (greddy style) along with the fuel rail so I bought a sard fpr it’s a knock off. Trying to set it a at 43psi without vacuum but it won’t raise or lower fuel pressure. It’s static at about 39psi ? I have it setup like so :
tank>filter>fuel rail>fpr>return to tank.
Anything i have missed or is it just a bad fpr? I know it’s a knockoff but it’s new and it should work?
Edited by r34.rory
Added pic
https://www.sau.com.au/forums/topic/473746-can%E2%80%99t-get-fpr-to-adjust/
What fuel pump do you have?
What size is the return line?
Is there any kinks in the return line?
What size is the outlet of the reg?
Knock off regs is just asking for trouble. It’s kind of important.
On 12/04/2018 at 12:19 PM, inmaniac said:
Shouldn't use a knock-off for something so important, such as an item related to fuel delivery.
Trust me.. I only speak from experience
Lol true.. I still have one fuel damper if that would even matter? the damper is about 3/4 inch after the return port on the fpr.
new fpr still not arrived so I went to have a look again.
11 hours ago, NEO25T said:
You havent got fuel going in the out port of the reg? Not sure if it would make a difference or not
Nah the outport is returning to tank. also tried another fpr and gauge and still can’t adjust either way !! wtf I’m f**king annoyed to say the least....
5 hours ago, KiwiRS4T said:
Replace the pump since you have one and eliminate that as a problem. If your new fpr still doesn't show 43 psi get an adapter for your stocker and use that.
yeah I think I will swap the pump out. if no success I will get the stock fpr and try a gauge on it.
Car was running fine before I changed the plenum. It’s sat for a couple months whilst doing so maybe the battery is weak I’ll check to voltage for the battery and the pump. What should the pump be getting do you know ?
Edited by r34.rory
7 hours ago, r34.rory said:
It adjusts down and needle doesn’t fluctuate. Gets to 3 bar and doesn’t get any higher and fluctuates. what’s a good brand fpr? Malpassi any good?
Nissan
Or if you want to spend more money  - Turbosmart or Tomei (but beware - lots of Tomei knock-offs around.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
