Someones having a worse day then me. :P Rule of thumb figures are:
- $1500 for a manifold,
- $3000 for a turbo
- $800 wastegate
- $800 injectors
- $2500 ECU installed and tuned
- $1500 intercooler installed
- $1500 exhaust installed
- $1500 clutch and flywheel
Then youll have a car with plenty of power but lacks the niceties such as:
- $1200 cams installed
- $2500 suspension
- $500 brake pads and fluid
It aint cheap.... for more detail then the above, then thee SEARCH button is our friend.
Thats rough figures, for new bits at retail...shop around you can get cheaper new/2nd hand and different brands
  • Replies 86
thanx heaps ROY....
ohh i aint saying i got a high performance car...im saying i want 2 build my car into 1...read properly an stop just jumping on ppl..
I see you've got no comeback about not being able to write English properly :cheers:
yeah well i know how 2 drive decent enough...an all i want 2 do is get the right turbo setup from the strat so i dont just have 2 get another 1 later....i aint going to run it 2 its full potential just yet either so dont worry.....
all i wanted to know is how much a minifold would be nd roy answered that 2 me...does anyone know anywere that sells manifolds 2 suit an external wastegate setup..i kant find any... thanx anyone who can tell me
Its cool to dream. :)
Mods take time and lots of money.
As soon as he realises how much he is really up for he may be happy with just 200rwkw or so..
As soon as you start hitting 250rwkw you have to be prepared should a motor to let go. There's another 6.5K.
Before you know it you've spent as much on the car as what its worth.
Do it in stages..
Exhaust, FMIC, bigger fuel pump, ECU then look at the suspension turbo manifold and injectors.
Go for a ride in benms car before you start thinking about needing a bigger turbo straight up. A well sorted std turbo R33 can be made to boogie :)
Like Joel said, its nota bad idea to get the basics out of the way (in order) like exhaust, filter, intercooler, cam gears, ECU, clutch...then by the time you are ready for a turbo you will have all the support systems with the exception of fuel pump and injectors which are dependent on how big you go.
I wouldnt call it dreaming, its planning ahead...i wish i had followed a more logical path to modifying my car...woudl have saved a lot of money and probably have twice the power...but its wise to have an idea of what it al costs before you start.
i have a 3" turbo back exaust, hks pod filter with cai, boost controller, tein ajustable supension.....an i will admit damn i was strugling 2 get traction already b4 i blew the turbo up...but since i have 2 replace i want 2 replace it with sumthing that has lots of potentioal..long long long term i want 300kw.....thats it..if i wanted more i would do a RB26 transplant instead..
ohh yeah ill tell be honest..i got offered a 500Hp garrett turbo that need an external wastegate for $400 brand spanking new neva been used an still in the box.. just want 2 see if i kan afford 2 do the whole setup properly...thats y i just need 2 know but modding the manifold or gettin a second hand stainless steel one 2 suit...
To get 300rwkw you will need an engine build with forged pistons.
Anything over 350rwkw and you will need a set of forged rods.
Simply doing an RB26 transplant isn't really worthwhile.
You are better off spending the $$ on a good set of forged rods.
Not many people go down this road as it is serious $$.
sorry joel possted at the same time as you...yeah i dont want 2 go over 300kw....would be 2 much for me...and i will only be running it under safe limits..like 250kw max untill i get more $$ to get forgies..
Even with 250rwkw be prepared to shell out for a rebuild should the thing pop.
If you want it to be reliable you will need to drop the compression ratio with a thicker head gasket, fuel pump, injectors, exhaust, fmic and an ecu.
Then on top of that all the labour to fit the headgasket, injectors and tuning of the ecu.
This will blow out to a lot more than you realise.
How much are you planning to spend honestly.
How much do you think you can afford?
not alot..as u kan c im only 17 an work part time when im not at skool....got ony bout $1600 to spend to get this turbo prob fixed at the moment...not much at all
What mods are already done?
So your std turbo is stuffed?
I would scour the forums for a cheap second hand RB25 turbo.
Spend $150 or so for a dyno run to check the af's.
If it is leaning out spend the rest on a decent fuel pump.
If you have already got the fuel pump sorted, spend the $$ on a PowerFC then save up for a little to get it tuned. Tuning is generally around $400-$600.
That will give you a big power increase depending on mods. :rofl:
joel thanx 4 your help mate...i just really wanted 2 get a good turbo this time...i only had the last 1 on 10psi an it kicked the bucket...but i will take your advise as that is what i posted this thread 4..to get advice
like i said b4 i have a 3" turbo back exaust, boost controler (turbosmart in cabin 1), really good HKS pod filter in a cold air intake box...
so you think just replace my turbo with another stock 1 ay....an my car is running really rich at the moment (fair bit of rich fuel smoke when i get up it)
brand new 500hp turbo for $400??
What truck did it fall off?
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
