Hi new here from the US and lack knowledge on if there is a non hicas pump I can use for my RB20DET as I tried capping the 2nd port and removing the splines inside the pump and even welding it shut still leaking. I used the search on here all I could find was hicas delete kits for the rear of the vehicle not the pump I could be searching wrong. Any help would be appreciated or a specific part number for the pump I would need.
Thank you in advance
https://www.sau.com.au/forums/topic/473750-non-hicas-pump-for-rb20det/
Yeah did some digging there is 2 different brackets that bolt to the engine for hicas and non hicas. The width where the pump bolts to the bracket is different so I ordered the bracket and I'm going to try the KA24DE pump I have with the new bracket
Edited by ThatGreyRBS13
