Hey guys,
I d like to ask for advice... My newly bought skyline running perfectly on 7 psi but if i raise the boost to 10 psi it cuts out at 6000 rpm and i just cannot tune it out.... when the engine is hot its getting worse (5500rpm)... I connected a  smoke machine to check for leaks...I marked the blocked pipes with red X....the smoke is immediately (at low pressure) coming out from the crankcase and from the inlet manifold...
It just doesn`t make sense to me how can it smokes from the engine when everything is blocked... Is my turbo leaking through the bearing housing back to exhaust and through the open valves comes out at the inlet? Or is it normal? Any idea? I m kind of getting hopeless for now maybe just i m the dumb and cannot tune it out (datalogit power fc, Z32 maf)... pls don`t spare me everything helps, have a good one
https://www.sau.com.au/forums/topic/473789-rb25det-turbo-leak/
Sorry about that i just didnt make a picture how the smoke was connected so i tried to improvise.... I connected the smoke to the inlet before the turbo (blue arrows).... I blocked the inlet from the intercooler so it should hold the pressure... but it s not holding any pressure since the smoke is coming out from the inlet manifold and the crankcase where the red arrows are with the ???.... And that s what i m asking if it s normal?
I assume you have the breather pipe and bov plumb back pipe blocked that comes out of your stock intake pipe. Try blocking it closer to the turbo, for example, block it before it enters the intercooler.
or, enter smoke right after the turbo and block off the same as your picture^^
NEO25T: I think I m gonna try it on the weekend
Kinkstaah: yeah it is an Apexi Power FC with Datalogit I have a log file what is happening...
the AFR at the cut point is about 10.75 (so it s not too rich or too lean) I ve tried to adjust the airflow data....change the whole MAF...still the same... after the car is hot the cut is happening at 4320 mV or less... It is a Garrett GT28 turbo, 7psi wastegate with a turbosmart tee set to 10psi
RB25detonator: yeah i ve done it too leaking out on the same places (crankcase and inlet)
Out of curiosity how did you block the pipes?
The easiest way i found was to bag the end of the pipe with black plastic and clamp it back together.
What spark plugs are in it, thinking back mine cut out like a rev limit at 6k when i got it. The plugs in it were nasty and new ones fixed it up
On 4/18/2018 at 8:50 PM, Ibanex said:
yeah I used rubber gloves with clamp for alloy inlet and for the hose used degreaser can and clamped it  for smaller pipes just bolt and clamp.
I thought about the plugs too and I changed them last week for NGK BCPR7ES... they should be fine right?
They should be OK but Iridiums better. If you still have stock coils are your plugs gapped down to ).8mm?
the only thing is that it really doesnt feel like a missfire...it just cuts out all together...  these plugs came already gapped to 0.8mm and the coilpacks (blue splitfires) should not be older than 2 years... so not too much left just keep on experimenting and spending some money...
If that is a full WOT pull, from the entirety of the video (i.e not backing off) and boost is dropping into massive vaccum like that, I'd be putting my money on that stock silicon hose sucking shut.
Especially given you said it runs fine on stock boost...
  • Like 1
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
