Hi guys,
I've been searching through the forum but did not find anything in relation to what I required. I was planning to go to Chris Rogers but found out on Google that he's shop is permanently closed.
I need both an alarm and an immobilizer and someone trustworthy (and knows how to fix it well) to install it too.  Car was recovered after being stolen and now mechanically repaired, need to have security fix and respray/vinyl wrap/plastic dip(?) done.
Also anyone have a rough idea how long would it take to install the alarm and immobilizer? just an estimate is fine.
Went to the ASIAL (Australian Security Industry Association) homepage but I have no idea where to look for those people as mentioned here
"I'd rather choose someone else. Who can I trust?
As a first point, I'd look up the ASIAL (Australian Security Industry Association) register, here."
Thanks guys
Edited by DragonX2X
  • 2 months later...
Alright if anyone is still interested in this topic, I manage to get in contact with Chris Rogers and he recommended someone to me.
Jason R from JJR's Mobile Auto Electrical & AC
Email: [email protected]
Mobile: 0402 299 513 (Servicing Brisbane)
 Jason came to my place to fit the car alarm, immobilizer and he did a great job.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
    • Yeah, they'll find anything they can. "Oh aftermarket ecu, that doesn't comply with emissions" lol.
    • See, I still thought it was 10 posts, and she was at 7 so I couldn't be bothered going in and fixing it when the fix was to simply post 3 more times. 8 more times....perhaps I should have.
