  On 19/04/2018 at 2:23 AM, niZmO_Man said:
I reckon you should take the wheels off and replace all the broken and worn out bits.
Expand
  On 19/04/2018 at 3:06 AM, GTSBoy said:
^ This.
Expand
Awesome, do you think the half shaft cv is where the broken and worn out bits will be
  On 19/04/2018 at 8:31 AM, GTSBoy said:
Shafts are piss easy.  Fall out from the inside.  Hubs/splines are obviously much more trouble.  You need to dismantle all this to find out what is wrong with it before you go buying stuff though.
Expand
Ok cool figers crossed its just the shafts.
  On 19/04/2018 at 9:08 PM, hardsteppa said:
Having had  the same movement, i rebuilt the cv's, replaced bearings, new bushes, new diff centre with perfect backlash...i still have the same movement.  However..images.jpeg.8136256e0d9e64410795ed90d9daa444.jpeg
Expand
For real?  hope i dont play that game
I learnt from gts boy and stepper and did sfa and noticed no difference. Car drives fine with that type of movement, even at 240+ km/h. My advice is leave it alone unless the wheel is going in/out from bearing wear, that would require attention.
ok now watched the video...looked normal to me. Diffs don't have zero backlash, they have a small amount for a very good reason, which is visible as a bit of turn in the driveshaft like that, when not under load.
the 5 bolt driveshafts on the r33 gtst use a 5-ball cv joint in both the inner and outer, which for most purposes is as strong as fk, there's nothing in there to ' break' really, only wear a groove at best, unlike the 3x2 bolt shafts which I believe use a 3x ball bearing race on the inner. I rebuilt a spare set of shafts and they had exactly the same movementousness as my old ones, which when pulled apart had no visible wear.
What I am getting at is if you're not having any ' issue' as such, the bit of movement like that is unlikely to be any concern.
Ok maybe It's nothing, there's no bearing movement. Drives normal only thing i can think of is I get an odd click when taking off sometimes was thinking that could be related. Not continuous just once.
Here's a vid of it, car jacked up in neutral handbrake on.
  P1370539_2.mp4Fetching info...
Handbrake off in gear.
  P1370541_1_1.mp4Fetching info...
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
