Hi guys just wanted to ask for your advise about the fitment of this crank collar.
The grub screws are drilled about 3mm into the crank, i have taken them out and not screwed them back in all the way.
My concern is it looks like the crank has been machined so the collar will slip on and loctite used to help hold it.
I hope im wrong but what are your thoughts, would you be happy to use as is, if not what are my options.
Thanks ?
Screenshot_20180424-085059_Gallery_resized_1.thumb.jpg.79d104de72293c6479712f2862b110ba.jpgScreenshot_20180424-085029_Gallery_resized_1.thumb.jpg.08c1d599654b1f4a1c98e59ccfe979ba.jpgScreenshot_20180424-085112_Gallery_resized_1.thumb.jpg.f1e720028c6649433f847420cd054f5f.jpg
Edited by NEO25T
Spelling
https://www.sau.com.au/forums/topic/473854-crank-collar-fitment/
They were like figjam do you know how many engines we do here, really poor attitude when i asked them about.
Said they would not have sent it out if that was the case but the owner didnt see it before i picked up.
Tone changed a little when i said it had red loctite and they wanted me to bring it back for them to inspect, but things got a little heated and i said i wouldnt let them touch it.
It's tricky to say for sure. They may have gone above and beyond and used the loctite even though it wasnt required. Or they realised it slipped on and loctited it.
Loctite is pretty good stuff, but for such an important part of the engine I wouldn't want any doubts .
Definitely sucks to not know for sure
  • Like 1
Im thinking lightly warm with heat gun and give it a twist to see if it moves.
On the other hand the loctite and grubscrews should hold it?
Possibility to have it welded maybe, im just not sure.
Hi octane posted a pic on facebook where a crank nose had snapped off, so ive got it on my head this is going to do the same lol.
Its dangerous when you have a little bit of information......
Its meant to be a shrink fit.  No loctite. If the grubscrews have been screwed into the crank you can be sure the collar has been fitted improperly. The  fix is to build up the crank with weld and machine it down to the correct size to achieve a shrink fit.
  • Like 1
Should be taken back to hear what they have to say about it. How many people work there, is there a chance someone dodgy in the workshop did the job?
The proper course of action is to have the collar taken off and sizes checked, you also want to see if they put a decent radius in the corner. Too small of a radius could lead to snappage.
3 hours ago, Ben C34 said:
, wouldn't it make more sense to just get a new crank collar made and achieve The Shrink fit with the new collar rather than welding and grinding a crank which would certainly cost heaps more?
Not if you can make the idiot who made the mistake  rectify it at his expense. Plus the holes drilled in the nose of the crank should be filled with weld. But failing that I guess you could get a new custom crank collar made but unless you had the means to make it yourself it would not be cheap.
2 hours ago, NEO25T said:
I wonder if different manufacturers collars are slightly different sizes.
Not a precise measurement but the crank measures 35mm where the collar slides on
The crank collars I used to sell are made in large quantities on  CNC equipment and do not vary at all or from Tomei or other collars. It is obvious that the person who turned down the crank made a mistake or just did not know what a shrink fit is... in this case the crank needs to be left 0.05 to 0.1mm larger in diameter than the ID of the collar.
21 hours ago, Dobz said:
So you're just going to give up that easy?
No just need a time out lol, im use to things not working out the first attempt or 2.
This car really should have been deregistered and sent to scrap but i kind of liked it so gave it a home, its been an interesting/ expensive 12 months of ownership......
Typical Skyline ownership, when my motor exploded I was going to strap and strip the car.
Somehow, a few cans later a few drunken discussions with people I ended up spending triple the car's worth and now have a built motor and a barely working car LOL.
  • Like 1
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
