I have recently started making some aftermarket gauge holders that fit 52mm gauges and fit into the stock triple gauge holder location on the r32 GTR. Some slight modification is required to get the unit to fit but once installed it looks just like factory. The only modification required is to cut a small slit in the plastic mounting location to allow the holder to slide up into its stock spot since the front plate is not removable like the stock on is. They are made out of 6061 Aluminum and four M5x.8 mounting bolts will be included with the unit. I am selling them for $120USD shipped to anywhere in the USA. And $130USD shipping to Australia. I currently have 10 units available. I will be making more based on demand.
I have tested this unit with both AEM and Defi gauges and both fit perfectly. If you have a different brand gauge just let me know what size the gauge measures across and I can verify for correct fitment.
I respond to Email quicker than I do a PM on the forum. So if you would like to email me at [email protected] that would be greatly appreciated
Edited by Malachi1364
https://www.sau.com.au/forums/topic/473857-r32-gtr-custom-gauge-holders/
Received my gauge holder which was very well packaged and had good communication from Ben. Looks very professional and well made so look forward to getting some gauges in it and brightening up my centre console! Thanks Ben
  • 1 month later...
I personally have never tried them on a gtst because I live in the USA and only know people who have imported GTR's. But if the Center console is the same then it should fit just fine. As long as the stock triple gauge holder from the GTR fits into your GTST then my part will also.
Also thanks Milhouse for the positive feedback! I appreciate it!
  • Like 1
  • 10 months later...
  • 9 months later...
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
