i had everything typed up last night and i pressed post and IE froze.
Z33 FairladyZ $87,498
VQ35DE
221kW/300PS @ 6400rpm
363Nm/37.0kgm @ 4400rpm
1575kg
3door 5MT E ATx
$20,839
CR12DE
66kw/90ps @ 5600rpm
121/12.3kgm @ 3200rpm
5door 5MT
$20,864
5door E ATx
$21,572
5door E ATx
$22,173
R34 GTR S-tune
RB26DETT S1 S-tune concept engine spec 1
400ps @ 6800rpm
45kgm @ 5600rpm
R34 GTR R-tune
RB26DETT R1 R-tune concept engine 1
450ps @ 7600rpm
48kgm @ 5600rpm
https://www.sau.com.au/forums/topic/47386-nismo-r-s-z-tune/#findComment-959017
Z tune is the more hardcore tune (basically turns the Nissan into like a M3 CSL - a track based car without making it totally useless for the street).
S is the "docile" one with mainly suspension and body tweaks. Engines get better breathing.
R is somewhere between the S and the Z.
https://www.sau.com.au/forums/topic/47386-nismo-r-s-z-tune/#findComment-959347
  • 4 months later...
Ok. That clears up all these Tuning Lingo. But what does N1 Spec means?
N1 is a race class in Japan that has homologated cars. Nissan put into the 32-34 series GT-R's steel-wheeled turbines (can hold higher boost without spitting the exhaust wheels down to meet Mr. Cat), suspension tweaks, bigger/beefier brakes, ATTESSA system fine tuning/reprogramming, some weight reduction (doesn't have an aircon) etc to homologate the car in order to race in this class :)
https://www.sau.com.au/forums/topic/47386-nismo-r-s-z-tune/#findComment-1138275
  • 2 months later...
