Hey everyone, last year my 07 Subaru STi had some mechanical issues and I decided to sell it and save on top of that for one of my dream cars the BNR32. I have been driving it for two weeks and am so glad that it has exceeded my expectations. The only thing that was missing compared to when I had my subaru was the community. After asking around I was told that this was the place for me. I am looking forward to being part of this community and learning from those that have more experience with the R32.
Cheers.
  • Like 3
https://www.sau.com.au/forums/topic/473866-hello-from-boston/
3 hours ago, ERO54N said:
Welcome angakh! What's it like owning one in Boston?
Hi there! The roads here are always in need of repair and with the suspension being stiff and lowered a bit makes me feel bad for the car sometimes. In addition to the roads we have some of the worst drivers so keeping an eye out for people reading a book while driving behind you has me on edge lol.
Otherwise its great, I love the way this car handles I really didn't expect it to be so tight and grounded around turns. I wish it was stock so I could see how it drove in 1989 before it was updated a bit.
  • Like 1
15 hours ago, niZmO_Man said:
Do you know of anyone (or a business) that imports parts from Japan? You could look at getting stock suspension from Japan, although I suspect they won't be as cheap these days.
Or grab some KYB/Koni/Bilstein dampers and Nismo spec springs.
The seller actually has the nismo suspension and is willing to sell it, but I like how it drives as is, its just that sometimes I don't see how bad a bump is or I miss judge it and when I go over it...it feels like the car is going to explode. And in that moment I apologize to the car.
The things that need attention are actually not that bad. Like the driverside window is loose and the squeegy liner at the base of the window has broken clips so when the window comes up it pushes it off. The glove box is loose and pops open over hard bumps, the vents need to be replaced, but mechanically the guy who owned this car took real good care of it. I am hoping I can do as good of a job.
Edited by angakh
clarifying the suspension is for sale not on the car
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
