G'day guys,
Well as some of you know, I wrote my R33 GTS-t off a few months ago and I've now got a RS Four-V :(
These bits weren't on the insurance policy for the R33 so I took them out before the car was sent to the auctions :)
TOMEI Master Brake Cylinder Stopper Bolts to the strut tower (there's two bolt holes there from factory) and stops the firewall from flexing under hard braking. Also improves brake feel at hard braking. I'd put this on the Stagea, but the alarm is mounted there and can't be moved :rofl: Selling for $60. SOLD
Nismo Black Chrome gear knob NEVER USED ! I bought and paid for this and while I was waiting for it to be delivered I had the accident.. Bought it for $110, selling it for $80. It has no scratches at all, brand spanking new... SOLD
Turbo HPBC bleed valve Perfect working condition, used for about 18 months. It has two valves in it, one to stop wastegate creep (adjustable) and the normal bleed valve. I had this installed with very short hoses and it barely spiked at all ! Bought for $135, selling for $75.
3 Gauges in a DIN mount All are mechanical gauges. Oil temp, boost and oil presure. All are VDO gauges and have blue bulbs in them. Comes with all the fittings you need to hook them up to the motor. The oil presure gauge is brand new and never used. I had a fitting made up and I was just about to put it in the car when I had the accident !! The front is covered in black leather that matches in with the dash pad. After $250 for them.SOLD
Factory R33 GTS-t front mats Good condition, have the factory 'Skyline' metal logo tag on them. $45 and they are yours. SOLD
Factory R32 GTS-t manual ECU Was planning on modding this and using it in the R33 GTS-t, but never got around to it. Not modified - totally stock $100. SOLD
Factory Din Pocket Took this out when I installed the DIN gauges. Factory din pocket with flip down front. Has a cut out in the back from where I had a Profec A mounted for a while. I got the $hit's with the Profec A and went back to the bleed valve !!! $20.SOLD
Happy to do COD post (may need a deposit) or direct credit, but either way the buyer pays for postage.
Email me at [email protected] or drop me a PM.
Cheers
Jayson
I honestly don't know.
They are a standard DIN size if that helps any, there is a piece of 3mm MDF mounted 90 degrees to the face that get's bolted to the frame that runs around the factory stereo cradle/mount.
J
Ahh, one thing I should've mentioned about the DIN gauges. The bottom part of the face on the holder actually sits behind the console - if you have a good look at the pictures you can see a slight wear line where the console sits against the face of the mount.
I just measured the face of the mount and the part that is viewable once in the console is 58mm.
I can email you the plans for it if you want to have a better look at it.
J
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
