33 minutes ago, djr81 said:
Have a 42mm PWR radiator. It never overheats and I am in WA where is can get hot on a track day and I run 98 not E85.  Down side is it leaks and I can never find the leak. Be the Nismo fkn cap then eh. Random post will help enormously: :)
Yeah throw that Nismo cap in the bin.
32 minutes ago, MrStabby said:
Ok thanks for the info. I happen to have a spare Tridon CB16110 here, so i'll use that instead of the Nismo that's on the CoolingPro. The Nismo is 18psi, whereas the Tridon is 16 psi (110kpa) as you probably know.
EDIT: Forgot to mention that PWR said i should use a 16PSI cap.
Yeah raising the boiling point of your cooling system by using a higher pressure radiator cap is not advised, as you'll end up in a big mess.
Close to OEM pressure is the best, you don't want that 20+ year old heater core or water lines going bang, if your water is boiling then there are other issues. No point putting on a stronger cap.
  • Like 2
Be very very careful with the PWR radiator and 'stray current' issues. They have a fairly poor reputation when it comes to warranty replacements.
Another good option is Race Radiators in Melbourne if you are looking for a custom setup, they just made me a three core twin pass unit with swirl pot. It was about $900 including the pot.
  • Like 1
Ok will check for that.
FYI for the thread - From: http://www.ipswichradiators.com.au/images/documents/FS119_-_Stray_current_corrosion_in_cooling_systems.pdf
1. Remove the radiator cap and run the engine to operation temperature. Do not rev the engine as this may cause the coolant to aerate.
2. Switch ON all electrical items including items.
3. Switch a multimeter to a scale of 5 volts DC or less. Ideally the meter should be capable of reading milli-volts. A digital multimeter may not be suitable for this test.
4. Place the negative lead of the multimeter on the battery negative post.
5. Dip the positive lead into the coolant without touching the filler neck or the core of the radiator.
6. A reading of more than .05 volts indicates the presence of potentially damaging stray current passing through the coolant. Ideally the voltage should be 0 volts, however it is highly possible that some voltage level will be detected.
7. If no voltage or a very low voltage is detected, carry out the same test as in point 4, but with the ignition OFF.
8. If voltage is detected, isolate the circuit by turning all electrical items OFF and switching each circuit ON individually.
1 hour ago, djr81 said:
Just so you know I am going to feel incredibly dirty putting this on my car.
http://search.supercheapauto.com.au/search?w=Tridon CB16110
could get a stant cap :)
Koyo has lifetime warranty, and they are easy to deal with.  Same with Mishimoto, which even offers collision warranty.  Both of them cost about half of other options I looked at, but I went with Koyo because they are slightly thicker at 48mm.
I am sure you have done this, but I think it's worth the time to double or triple check if the whole system is bled properly.
New Koyorad is a 48mm (rather than old 53mm) so you get better clearance to fan/shroud and it is apparently more efficient. I make around 580kw at the hubs and I tend freak out when it hits over 90C but only really heads that way after a belting and sitting idling, drops temperature when air is flowing at speed.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
