2011 Kawazaki Ninja 250R
$1600, you will not find a cheaper one, priced to sell as I would like a quick sale
Rego till Jan 19
26k km
Good tyres
New brake pads
Serviced by me every 2k km
Engine oil, oilfilter, brake pads, full brake fluid flush, new coolant, new front and rear sprockets, K&N air filter, service done about 500km ago.
Adjustable rearsets
Mussi exhaust
R6 throttle tube (less twist for full throttle)
Clean bike
Used as a daily commuter
Selling because I grabbed a ZX636R
https://www.sau.com.au/forums/topic/473905-2011-kawasaki-ninja-250r/
24 minutes ago, Birds said:
Man that's cheap
I looked on bikesales for the cheapest one and went $100 less.
Hopefully a quick sale.
I'm going to put it on bike sales tomorrow, hopefully it's gone this week.
I have no doubts it will. These are great little commuters. If only I had a need for one again. Please don't take any less than you're selling for!
5 hours ago, barraspalding said:
oh, a fuel gauge!
So much better than running out of fuel and fumbling for the pet cock, LOL, I said cock.
I'm also coming to terms with the ZX6R fuel warning light, I am on its first tank of fuel, I keep waiting for it to come on, and quietly hoping the globe isn't blown.
Yep my 02' zx6r (the first of the 636's!!!!) Had the fuel tap... cock. Silly idea.
Gd luck with sale. Crazy cheap
For $1600.... if you dont already have it, good quality riding gear.  My pants alone were $600 but they are gooooood.  The distance between my actual knee and the outer knee puck is massive. Sure makes me feel alot better about riding and the 'what if' factor.
Got all the gear, new boots are on my radar though.
I'm liking the A* shorties, just under $200, protection where I need it and pretty comfy too.
Big plus is they are OK for walking around in, my current boots, which have seen better days, are rubbish for walking anymore than 10 meters in.
Can't recommend highly enough kangaroo leather gloves
A* GP Pro I think mine are
They were exxy but the tactile feedback is second to none
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
