Tools required:
Heat gun/big oven, grinder, drill and a basic tool set.
Time: half a day if you really take your time
I believe there is already a diy on how to remove the headlights from the car so please refer to that.
This retrofit was achieved by using the morimoto mini 7.0 h1 bi-xenon kit which i purchased off ebay for $180 inc shipping from the u.s. There is also a diy for r32 headlights but i can confirm this kit works on r33 s2 headlights. The kit literally comes with everything required to install the projectors, including new sealant to go around the headlight lenses. This tutorial is assuming you have already installed aftermarket hid ballasts and bulbs, which is the easy part anyway [emoji5]. Not sure if the r33 s1 headlights can still retain the factory reflector housing but not much modifying was required for the s2. Firstly you want to remove the headlights and remove each metal retaining clip around each headlight and then put them in an oven for about 5-10 minutes to soften the sealant and then carefully pry the lenses off bit by bit. in my case i had to use a heat gun as my oven was too small[emoji54] now you want to remove the factory bulb holder on the back of the headlight which is held in by 2 little screws. You wont be reusing this part as the kit is supplied with a new one. To remove the reflector housing i found that by loosening the horizontal and vertical headlight adjustments on the back, it was much easier to just pop it off the ball joint as seen in the pictures. Just be careful not to lose the adjustment nuts as you will be reusing them. now see the raised plastic bits on the back of the reflector housing? You want to grind these off and have the surface as flat as possible so the tightening nut has enough room to get a secure hold on the back of the projector. Before putting the projector in, you want to screw the projector housing on with the supplied screws. I opted for the mini gattling shroud and couldnt be happier with it! In order for the back of the projector to go through the hole in the back of the reflector housing, you will need to slightly enlarge this hole with either a dremel or a drill bit but be careful to not crack or chip the housing as its only fiberglass. Now to pop the projector in the reflector housing while making sure its mounted the right way and also remembering to put the adjustment nuts back in. There is an 'up' marking on the projector so you cant really stuff this up. Also,refer to the instructions that came with the kit as you dont want to redo this later. I also used the supplied rubber washer when tightening the nut. You want to make sure the nut is really secured with a shifter as the last thing you want is for the projector to come loose and have to reopen the headlight to tighten it up again. With this kit there is also an option to wire it up so the projector stays on when the highbeams are switched on. I skipped this part as its not necessary and didnt really appeal to me. A hole would most likely have to be drilled in the reflector housing to run the supplied wiring harness out the back of the headlight. Once the projector is in, you want to run a length of the supplied rubber sealant around the entire headlight and try to push it in the groove as much as possible. I removed as much of the old sealant as i could but you dont have to worry about removing every last bit. Ive washed my car several times and driven in the rain with no leaks what so ever. Now with your heatgun you want to heat up this sealant and press the lense back in with as little mess as possible. Dont worry if some sealant presses out as it can be cut off with a knife once its hardened and made to look like a factory finish. I went around the lense a few times with the heat gun and put each retaining clip back on, working from the center out. Once its all back together you will definitely need to find a flat surface with a concrete wall or garage door and park roughly 6-7 metres from the wall to readjust the headlights. Proper instructions/methods can be found on google for this step. Now to enjoy having much better visibility at night [emoji5][emoji5]20180324_144804.jpg20180323_132430.jpg20180324_145506.jpg20180324_145453.jpg20180324_145533.jpg20180324_150542.jpg20180324_151806.jpg20180324_152735.jpg20180324_153649.jpg
  • Like 4
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
