Still a few spots available for a blast around Winton next weekend in the crisp Autumn air, perfect for PBs!
You don't need to be a club member, but you will need a valid CAMS/AASA and a car that will pass scrutinizing.
Cars are split by class, prizes awarded for class winners, and there's plenty of track time for everyone. there's even a top 10 shoot out at the end of the day for the 10 fastest cars.
Official timing is included in the cost, only $150 for the day!
I might be a biased, as this is my local club, but it's a great bunch of drivers, a good range of cars, and always an awesome day out.
I'll see you there :D
Sign up: http://www.awdcc.com.au/?p=2134
Facebook group: https://www.facebook.com/groups/awdcc/
Edited by ActionDan
Hey Dan, im interested in coming along. Was just reading the supp regs and reg 42 says.
  -All laps will be in an clockwise direction of the 2000m circuit
Was wondering if the event will be run on the full or short course as 2000m sounds like the short?.
Cheers Bill
[mention=139042]admS15[/mention] Good work yesterday, you came second in class.
Thanks Dan, i actually ran a 1.37.75 which may have made me first on my last lap of the day but it didn't count as the red light for end of session came on as i came out of the last corner. I knew i was on for a good time, race chrono was showing me greens, so i kept going. Robbed unfortunately but I'll count it as a pb for me.
Overall, event was run quite well, good turn out, nice bunch of blokes and some damn quick cars. Wouldn't hesitate to enter another one of your clubs events.
Not bad for a CA powered S13 and a street regd R33 on Nankangs. We probably could have both been a second quicker if the nankangs where brand new.
Was happy to run that time and still be able to make the 3 hour trip back home.
Was nice to meet you too and finally put a face to the name[emoji106]
  • Like 1
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
