Hey all, It's time to sell my stagea...
https://www.carsales.com.au/cars/details/Nissan-Stagea-1997/SSE-AD-5412679/
1997 Nissan Stagea WGNC34 DAYZ AWD RB25DET
Engine and Ecu:
Rb25det
Turbo - New Hypergear Atr43g3sat with braided lines
Injectors - 440cc Sr20 with new O rings
Computer - Adaptronic e420d
xforce 3" Downpipe
Catco 770 catalytic converter
Trust 3" exhaust with electronic Y pipe
Walbro 255 fuel pump
Front mount intercooler
Splitfire coil packs
MAP
Wideband - Innovate lc2
Re4r01a gearbox
Interior:
Leather seats
S2 wood fascia
Floor mats
Cargo net and blind
Rubber mat
JVC headunit
Rockford fosgate speakers
Suspension and Brakes:
MCA Blue coilovers
Whiteline F+R ARB, Rear camber arms, Traction rods and Adjustable Caster bushes
R33 sumitomo F+R calipers with remsa pads
DBA T3 rotors F+R
Nismo Front braided lines and APP Rear braded lines
Cusco master cyl brace
Exterior:
N/a grill
350z track wheels with near new 245/40 tyres
Xtreme paint protection
Fun, comfortable and reliable daily driver. If a part was wearing out, it was replaced with genuine nissan or proven aftermarket. e.g: genuine nissan 2x front drive shafts, tie rods, upper and lower front control arm bushes, etc etc. There is way too many things to list, as you can see from the photos.
SOLD
  • Like 1
https://www.sau.com.au/forums/topic/473919-nissan-stagea-1997-dayz-awd/
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
