Hey guys so my RB25DET Blew up (Got sold a hand grenade) Piston 6 Failed filled the engine with fuel that mixed with the oil and then f**ked the turbo I've spoken to the workshop and they reckon the only thing in the engine salvageable is the Block itself so a rebuild isn't viable so i need to get a hold of a RB25DET Series 2 (1997) Motor with relatively low K's and full compression to drop in as im already out of pocket 9,000
I was wondering if any of you knew any reputable engine salesmen that may have a S2 RB25DET to drop into it?
Cheers
https://www.sau.com.au/forums/topic/473925-r33-questions/
This is 2018 so there are not going to be many low mileage RB25DETs around. Your best bet is a rebuilt motor where someone has written off the car. Have a trawl through the parts for sale section of this site.
https://www.sau.com.au/forums/topic/473925-r33-questions/#findComment-7874286
Find a motor from an auto 4x door or an auto Stagea (that's what I did), but because I'm an idiot I decided to rebuild a perfectly good motor Lolololol.
You should be able to pick one up for under $1500, also I suggest a new head gasket, ARP studs and your vanilla 100k service on it.
https://www.sau.com.au/forums/topic/473925-r33-questions/#findComment-7874302
I got my Auto Stagea motor off Gumtree  120,000k's  bores were like new and Dose Pipe i'm no idiot I rebuilt too, sensible people do, search the net everyday and you will find, Good luck and welcome to the rich and rewarding often frustrating Skyline world.
https://www.sau.com.au/forums/topic/473925-r33-questions/#findComment-7874329
