Well the standard auto we have has cried enough, this is after three months of trying to get the standard RE4R01A to play nicely with the nistune ECU much more work required by Nistune to supply auto ready ECU's methinks I own many TCU's now trying to make the box work properly. It did'nt like the torque produced by the 30/25 from day 0ne. So today it went in for conversion to a Z32 TT auto the RE4R03A also used in different configuration in Patrol, Joel at JD Auto is fitting a manual valve body , modified torque converter new flex plate to suit and modified tailshaft, oil cooler and normal pattern gate shift . Should be good for 600 hp according to previous conversions. I am looking forward to loosing the TCU and finding out how hard the car really goes without flare ,slip and not changing up.
Edited by Rusty Nuts
https://www.sau.com.au/forums/topic/473928-r33-auto-upgrade/
I have matched TCU with ECU from R32 i'm not bloody stupid mate and read the threads on Nistune before becoming an instant expert there are many of us who have had problems with auto's and Nistune is aware as far as I know. We have tried four TCU's and two auto transmissions, changed speed sensors and corrected speed signals to no avail. Its not as simple as you seem to think. Hence my comment more development required.Its definitely the nistune ECU when the R33 ECU was reinstalled the engine ran like shit but the auto worked
Also through out this entire process, Consult threw up no error codes which made diagnostics difficult (impossible) hence reverting to checking signals were correct for ECU/TCU/TRANSMISSION combination. also hours spent checking wiring was correct and not compromised.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
