Hi gents,
Came back from a two week holiday and did a service on my R33 s2 Rb25det.
Changed Oil, cleaned afm with electrical cleaner and swapped back from pod to air box and snorkel with trust filter. I run a air box 99% of the time.
I was giving it a boot at night on Monday and noticed it wasn't as quick as it normally would be with less of a punch in the mid-range. Basically felt like it would on a hot summers day, rather than 10pm at night heading into winter.
As it's SAFC tuned I can see the AFM reading as a percentage and normally in summer it would hit 76-80% and in winter 82-87%
It was hitting low 80's this night but just felt slow.
Started fault finding, re-cleaned afm, checked fault codes, Checked for loose hoses etc
No obvious boost leak, still hitting and holding 10psi and turbo is not any less responsive than usual. Removed air box filter lid/filter/snorkel for a run and only marginally quicker but didn't seem like it was the issue.
Replaced the fuel filter too, no difference.
I then removed all corrections on the safc so it was essentially just running stock and I couldn't tell the difference.
Kept doing runs with 0 corrections and then adding the corrections it was tuned for and I can't tell the difference.
So now I'm at a bit of a loss, I don't have a wideband to see if the corrections are effecting open loop AFRs  or if the fuel pump is dying. Had a walbro put in at the time of tune 5 years ago.
Basically it's had the same setup, 10psi, MBC, return flow and full exhaust with SAFC tune for 5 years and all of a sudden it just feels like it's slower like it's lost its tune/less ignition timing.
Any ideas, whether could be fuel pump dying, still a marginal boost leak or a problem with the SAFC?
Just want to try anything before getting it on the Dyno.
Cheers
Patrick
I would suggest getting a wideband gauge if yr using an safc. I think my aem one was under 300? Have had it a few years on car and still going strong. Otherwise yr shooting in the dark adjusting safc, and in the danger zone. .not the good Kenny Loggins type either
Thanks for your response.
Yeah this is basically the next step.tried
First measured voltage at VCT plug. Requires 2ppl, as car must be in gear.
Voltage was there, so removed vct and made sure it would actuate(audible click) and visually see the Piston move using the battery. It didn't the first go but then after re-applying 12volts it did.
So cleaned it up, re installed with plug on and made sure I could here it audibly click/engaged.
Ideally I could have done that from the beginning but nevertheless it solved my issue.
  • Like 1
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
