Hi,
Have a new R32 GTR in the stable. It's a long story but suffice it to say I have very very little information on this car and it will, in the near future be heading to a mechanic to see exactly what has already been done.
It already has a big single turbo conversion that is super laggy, full boost at like 5100rpm.
Straight to the very weird question:
I only want to make 400hp at wheels, I want the absolute best street response up to that power level.
Putting twins back on is cost prohibitive.
Best single for my purpose?
Thankyou
10 hours ago, WantGTR said:
Gen ii 3582r. More responsive than any twin setup and will make more power everywhere. Plus lots more than 400hp
Thankyou for the suggestion. Just had a quick look, with a power range of 450 to 800hp it seems way out of my needs, especially coming in at $3,200.
Does anything else offer good spool up time, more of a 450 top range and come in a bit cheaper?
I do realise that a 450 to 800 HP window is a great investment at $3200 if you think you might upgrade later but I'm 100% confident I'm happy with 400-450hp
How much are you expecting to spend? What is the current setup? You can take a punt and buy a china version of the turbo if you want to save money. Its a waste but its cheaper.
I'm not adverse to spending money, I just think if GCG are for example selling the GTX3076R for sub $2000 (admittedly for the RB25) with a 350-550hp range then there must be something in that price range to suit my needs for the rb26.
I have also emailed gcg to see what they can come up with.
3 hours ago, Piggaz said:
7670/1.05
e85
supporting mods
go.
Not keen on running E85 to be honest. Has to be achievable on pump gas
22 minutes ago, Griffin said:
Borg Warner s256 or similar. Unbeatable for value and reliability.
Don't get caught in the crowd like all the other sheep on the forum. Do what suits your needs.
Plenty of cheque book racers on here will tell you otherwise.
Thanks mate, I will check it out now
There's no difference in the application.  For all intents and purposes, once you take the twins off a 26, the turbo to make any given power level is essentially the same thing on either engine.
7 hours ago, GTSBoy said:
Next size down is GTX3076.  GTX turbos work best at high pressure ratios, so you might even be better off with a non-GTX (ie, GT).
Or, you could go to Borg Warner's matchbot and play with selecting from their offerings.  Likely cost more.
I would go GTX3576R and a nice 1.xx rear divided housing.
Twins are not responsive, nor are they great for transient response. You need a good twin scroll setup, from what you may have there - it "could" be a dinosaur single scroll setup with a turbo from the 1990s.
I'm using modified factory twin turbo manifolds with a single twin scroll housing, single 40mm waste gate.
Starts making usable boost from 2000 rpm. Power holds til 8000 rpm without dropping off.
Total cost of $300 for turbo, $4 for 2 x gaskets, $13 for marmon flange . Plus bits I had laying around and a tune.
What turbo and how much power does it make?
1 hour ago, Griffin said:
A borgwarner s256 ish off a diesel tractor. Touch under 400wkw. Left the 305 semis on. Not sure if the number would be different with smaller tyres.
If you ran it on the dyno with smaller street tyres it will read higher :)
What fuel for that result?  I'm thinking E85.
Post up dyno sheet with torque curve if you've got one!
S256 is still a very good unit, given its age.  Application is on a John Deere harvester.  There's an updated/higher flowing unit too, called S257SXE.  Both built to deliver/handle high pressure ratios, so the thrust bearing is good.  I nearly got one but BW Matchbot and a bit of consultation with Full Race indicated they were a touch small for a 30DET.
Very good match on a 25/26 capacity and a comfortable 450rwhp on petrol.  If I still ran the short stroke bottom end, I'd go for one and spend on a twin gate/split pulse setup.
The new price vs performance for these things makes them a no brainer up against "budget" and "entry level" units.
That's without ecb connected. Single 40mm wastegate, twins aren't needed  imo. Turbo is extended tip compressor. The one I took off is from a CAT engine. Same size wheels with a different size/ shape rear housing. That's going on a 2630 now. Aiming fora responsive 300kw on p98.
That one has been on the rb26 for about 3 years trouble free. Not a drop of oil anywhere and zero wear.
Edited by Griffin
Typo
  • Like 1
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
