thankyou so much for taking that photo i really appreciate it, after examining it some more i noticed its cracked at the base of the filler neck on both sides, so are the top tanks replaceable or is it possible to grind a channel into the crack and fill it with a special glue, i mention this cos i remember seeing some glue and powder repair kit and on the video for it they show repairing a huge crack and they filled it with that stuff, you put some powder in and then some glue and it soaks in and then you add more powder and glue again and keep building it up, so has anyone done this or know anything about that?
You cannot repair them mate, if top tanks are available i've never seen one, I plastic weld with a Lister, but never radiators or fuel tanks. All those epoxy based filler glues are snake oil they don't work. If moneys a bit short grab a second hand one plenty of options in the big city There are even cheap all aluminium ones although take a good look at the welds some look a bit work experience.
this is where its cracked on the base of the filler neck, so does anyone think using a proper plastic radiator repair glue they sell at auto stores will work on it?
As you can see it has a crack that i can see on each side of the neck but i dont know if thry are 2 seperate cracks on each side or if its one long continuous crack
i thought about getting a secondhand one but was worried that most of them probably have been laying in a backyard and not had the openings blocked up and the core is probably full of spiders and rust and god knows what.
I also thought since the crack is just on the neck that it might be ok to repair
Hey Mick I took the photo for you and explained that the crap they sell to fix them does not work, and wishing it will is for the fairies,  Get a second hand one or ebay alloy and be done with it. Asking the same question over and over will not fix it.
On 5/6/2018 at 8:00 PM, Rusty Nuts said:
You cannot repair them mate, if top tanks are available i've never seen one, I plastic weld with a Leister, but never radiators or fuel tanks. All those epoxy based filler glues are snake oil they don't work. If moneys a bit short grab a second hand one plenty of options in the big city There are even cheap all aluminium ones although take a good look at the welds some look a bit work experience.
If you dont know how to flush your coolant system, your friendly local rad shop will flush a second hand one for you for peanuts, I always laugh when someone says " I have a little coolant leak", its the same as saying your girlfriend is a little bit pregnant, both are gonna get bigger
if you actually read you will see that i only reposted the photo to ask what the bolt hole was for.
Then after posting photos of where the crack is and what it looks like i so people could get a better idea of how bad it is i then asked if anyone thought the proper plastic radiator glue would work.
I dont see anything wrong with doing that at all
Mick, there is no such thing as proper plastic radiator glue, radiator plastic tanks are usually ABS and can be originally made from material made by Monsanto, Dow chemicals or a japanese/chinese Manufacturer and are difficult to WELD because of this, they have also been subjected to hundreds of hours of heat and fumes which alters their composition, flexibility etc. Hence why even welding is unreliable, their is NO glue that will fix them, you have all the answers mate, and no answers say use this glue its awesome, because they dont work. Bite the bullet and buy another radiator mate, over and out.
I took the photo you requested Mick, in your ORIGINAL post 13 days ago and I did not and i have not referred to your repost. Suggest you reread the thread. I have.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
