Hey gents,
So I've been chasing blood (oil) loss from my rb25det NEO....
Basically it's soaking the inside of the timing cover and dripping down the front of the oil pump and sump etc,
Now, many hours have been spent attacking the usual culprits for this nonsense: genuine valve covers, half moons, cam seals and front main seal have all been replaced with genuine gasket goo to help. I also re torqued the head studs while the covers were off.
To my displeasure I pulled the timing covers off again today and she's still bleeding. I fear it can only be coming from the head gasket seal (or lack there of)...
The head was recently (6 months or so ago) reconditioned and ARP head studs, Tomei metal (standard thickness) Head gasket and tomei poncams went back in with it (would have been rude not to...)
The place I took it to obviously made it clear they needed to get the deck of the block as smooth as a babies ass in order to seal it with a metal head gasket... I'm thinking perhaps she wasn't smooth enough... But it's certainly not leaking compression so I'm scratching my head a bit cause there's not much room between the front of the block and cylinder #1... surely if it's leaking oil that far foward it would leak compression aswell?
I'm uploading pics of where the oil is pooling on top of the water pump for your viewing pleasure.
Anyway I guess I'm at the point where I'm trying to work out:
A: Are there ANY other spots on the front of a turbo NEO where oil could get into the timing cover ( VCT maybe?) That people know of?
B: If it does turn out to be the head gasket, could I just one-for-one it with a genuine HG without getting the head sent to a shop (Again) cause its still newishly refurb'd or is that bad joojoo? (Also not pushing much boost or power... I was just future proofing it)
C: Bite the bullet and start looking for/ organising a rebuilt long motor since effort is required either way
D: Attempt to convince the shop I took it into that they should really help me out..
(I don't like my chances here because all other seals weren't installed by a 'qualified mechanic', so f$#@ery could ensure)
There's tons of experience and genuine dudes and dudettes on here and any input, advice or opinions would certainly go towards the brain storm.
Thanks guys if you read this far.
20180504_103602.thumb.jpg.37cf6fd75df2a1d40acef3c1c33b2434.jpg20180504_101524.thumb.jpg.e96cd6b49f2e87ce454250daaa57af40.jpg20180506_153214.thumb.jpg.c7594637910612a830a21e0b9544f4de.jpg20180504_104824.thumb.jpg.5f230f9c5b06a3f16cb8bf253651fb2f.jpg
Check the vct bolt is tight , what about camshaft seals?? Unfortunately a drip near the gears can throw it everwhere, but I've had an external oil leak from head gasket which didn't spread to the cylinders ( on a BMW not RB25) check the easy stuff first then take the car back to get the head gasket checked There are no seals that can effect their part of the work because you eliminated any chance first by checking the easy stuff
If there is a substantial groove in the crankshaft it will never seal no matter how many new seals.
Yea it was all pooled down there... But when I changed the seal Just to be certain, the one I pulled out was bone dry, if there IS a groove i guess I'm pretty screwed anyway [emoji17]
I'll check the VCT bolt tonight for sure, otherwise Yea, might have a chat to the dudes who did it.. cause all the easy stuff has now been changed and checked
Was there oil present on the rear face of the Harmonic Balancer? I have in the past shimmed the seal forward 1mm when removing the engine was not possible. Its fiddly and a bodge but it worked. I got the shim from Blackwoods they have a large range in their catalogue. Oil leaks are a PITA wish you all the luck in the world mate
Hmm the balancer look like it only had some sprayed oil from the timing belt and sprocket going around... But I'll have a look into this. Thanks heaps for the info !
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
    • As somebody who works in the energy sector and lives in a subzero climate, i'm convinced EV's will never be the bulk of our transport.  EV battery and vehicle companies over here have been going bankrupt on a weekly basis the last year.
    • With all the rust on those R32s, how can it even support all the extra weight requirements. Probably end up handling as well as a 1990s Ford Falcon Taxi.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
