$10k worth of discs?  Where's the value?  I'm assuming that they will be going back onto the Audi and not actually being used on the track, right?  You do realise that all the Audi/Merc/Porsche owners with ceramic brakes take them off for track work, or even for street work, then put them back on to sell the car with?
  • Haha 1
thumbs up to GToFuS-T. being first worth every cents.
besides we work with AutoRacing Technik. we get our pads custom made, not going to get ripped from euro car makers.
  • Thanks 1
1 hour ago, niZmO_Man said:
Got some spare rotors? Price of those?
got a set of 355 rotors with 4 pots genuine ferrari brakes with adapter available. if interested. for skylines and silvias. M12 bolts. but in steel tho.
$2k for the whole setup.
Edited by godsmind
A gentleman with an incredible NISMO spec build fitted some to his car approx March 2016, I don't want to steal his thunder but it is here (along with the rest of the build - definitely not works safe, incredible car!).
Interested to know your thoughts regarding performance, etc. I don't believe ALL cars that have them stock take them off!
Thanks for the info. Being first in Aus isnt too bad either..i guess:D
Nice nismo built for sure. With performance, it certainly alot lighter than steel discs. yet to find out what is is like and temp range with the custom pads. Not sure if ALLLL cars take them off buddy, certainly the people i know have them on all the time.
Edited by godsmind
Just went through the previous photos. i believe the discs they used are too big, the 35gtr caliper are too small for the disc. the pistons arent really pushing to the center of the pad/disc. Unless i am looking it wrongly?? here with pics of the two setup vs stock. can see there is a big gap between the edge of the caliper and the center hub. As well as the excess material of the pad. guess the pads will be pushed in in an angle causing uneven wear and poor braking performance. Everyone's thought?
0001413_nissan_r35_alcon_racing_380mm_rear_discs.jpeg.67a58222902e124d91606193b976b03c.jpeg5af386709b4a6_canadacarbondisc.jpg.d5b95af58ae480975fe080870934dd79.jpg5af386718e07e_nismobuilt.jpg.949b21f7519b105dd7aae219a6680a94.jpg
Fitment of caliper and pads on the rotors doesn't look right.
That's what happens when they're not really fitted - just sat for e-fame photo op.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
