31 minutes ago, Leroy Peterson said:
OEM would be designed for comfort and longevity vs strength and handling, non?
If looking for upgrades, then OEM isn't an option.
This one is just my daily. have a track car for fun!
1 hour ago, djr81 said:
Then buy the NIsmo version.
Nismo arms solve nothing.  They are actually worse in almost every sense.  They only make sense at stock ride height when combined with the Nismo upper bracket and the Nismo caster rod.
The problem is that they are shorter than the stockers.  Most of us actually need to lengthen the upper arms to undo the extra camber from (even sensible) lowering.  Only need ~1.5° of camber on a streeter, but can easily have lots more than that (and also different values side to side) with stock arms.  This is where the GKTech arms looked good to me.  Apart from Duncan's shit news about someone breaking one on the track, they look strong and they handle the twisting that gets jammed into the FUCA when the 32 suspension moves.  Oh...and they are adjustable for length.  I had to lengthen mine compared to stock to get the right camber, and had to have the RHS one ~5mm longer than the left.
In reality, adjustable poly bushes in stock arms would make a lot of sense, if they didn't get annihilated by the incorrect geometry caused by winding on even just a tiny bit more caster.  They even crap themselves without winding in any extra caster.
I'm not shitting on gktech, they do handy parts that don't cost an arm and a leg, but most are billet items from China which have broken on time attack cars. I'm sure drifters have broken heaps of stuff too, but they break everything.
I was referring to bushes alone, not arms.
I hadn't ever heard of anyone wanting to lengthen front upper control arms. The overwhelming experience is to do the opposite.
After looking for ages I gave up on finding a decent UCA and made my own.  It is worth contemplating if you have access to someone with fabrication skills.
The other point to make is don't run a rod end castor rod.  This is where compliance is built into the suspension and removing it trashes your UCA bushes (The rear one, usually). You can get adjustable for length rods with bushes at the front end.  Hardrace from memory.
Funny thing is, I have those red ones from Just Jap. I didn't fully tighten the adjuster bit so it can rotate with the suspension.
It's been fine for 3+ years, although my car sees mild use compared to the track people here.
Shame to see the GKTech ones break, I have there rear upper arms and they've been silent for the same period of time.
I did have Hardrace front upper arms to go in, in case the JJR ones went noisy, but I sold them off.
I just rebushed my rear with full nismo (bushes only) including subframe and diff.
However as the car is around 355/345 F/R there was too much camber with the upper rear arm so used the Nismo pro rear upper arms which took the camber back to -0.8deg.  Have a set of new set of Silk Road track and camber arms in case it wasn't right but happy with it now and the OEM eccentric bolt gives enough  although cannot go past 0.8.
Front has Ikeya upper with Nismo bush outside and Ikeya castor rod (hard rubber bush model)
Mainly road car with occasional track day.  Still drives good on the road.
Ah, but there's the rub.  Rod ends make the caster rod work like it should - stops the wheel moving fore-aft under load.  The car improved out of sight when I replaced adjustable Whiteline urethaned caster rods with Teins.  I've been preaching that line for years.
With the GKTech FUCAs, I set them to stock length when I installed them, having no other guide to a starting number.  Ended up with a bit more camber than I wanted so had to wind them out a few mm.  Car is at legal height.
Had a Cusco Pillow ball  castor rod in there for the last 10 tears, if this rubber one is not up to it I'll change back. So far its good.
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
