On 5/10/2018 at 3:06 AM, Rusty Nuts said:
The solenoid is different and does not work in non neo engines, the vct is different too,  as GTS boy said they are specific to neo engines. Neo vct cuts in much earlier, from idle, and is active all revs to 5700rpm for turbo and 5400rpm for n/a wheras earlier RB25 ranges are 1050 - 5700 and 1050 - 5400 respectively
On the R34GTT the solenoid is activated via engine 'Load' which is called TP in the Nissan world.
It is not engaged via an RPM trigger. It is disengaged @ 5400rpm.
There's also a minimum temperature of 70C for the solenoid to work
Effectively 'd say VTC kicks in at around 3000 if you were to put the pedal to the metal.
Edited by Torques
On 5/11/2018 at 10:44 AM, Rusty Nuts said:
I am quoting Tomei and a standard ECU there was no mention of Nistune in his enquiry. I am using Nistune in mine and using the start point at 1050rpm because the VCT internals lasts longer physically if its actuated when oil pressure is higher, they tend to "bounce" internally at idle
As I said mate i'm quoting Tomei and I put a test light on the vct output and it lit above 1050rpm. If there is 12volts there what other conclusion can I make??
I know you are in pommyland mate but how long do you think it takes to hit 70C over here in the land of Downunder.
We don't need those little engine heaters to keep our oil warm overnight like my old man used under his Sunbeam Alpine when we lived in Manchester.
Mine is a RB30/25det neo. In a R33 auto with Z32tt fully manualised auto running R32 Nistune so thanks for the chart but has nothing to do with my setup.
Edited by Rusty Nuts
And this was the subject as I recall. Not interested in a spitting competition either.
And yet, that's how it seems all of your above posts read.  Not a bad effort for a newbie to come in and take the mantle of prickiest poster, but there you go.
  • Like 2
You completely lost me here maaaate :)
I merely stated what the OEM ECU does. 70C+, TP of 56, OFF @ 5400, and no fixed RPM for on
No competition intended!
Edited by Torques
Mate the chart is from Nistune, and I replied to your statement about the OEM R34 GTT :)
I also do run the Z32TT ECU on NT .. so I think there is some overlap to your setup ...
Edited by Torques
On 5/10/2018 at 11:33 PM, Dose Pipe Sutututu said:
Regardless of NEO or non-NEO the RPM where it is enabled or disabled is 100% configurable if you're not using a PowerFC or Stock ECU.
The window where it stays on should be tuned till when torque starts to decay, of course this is all dependant on what parts have been bolted to the motor.
Generally for me, I will do one run with it turned off and one run with it turned on past max torque ie close to red line and overlay the derived torque graph. The intersection point is optimally where it is turned off. Also once off, the motor will happily take more timing
Yes, that's the best approach ... one run off, the other one constantly on.
Edited by Torques
Has this ever been done as an example as to when to turn it on?
I had always heard it comes "on" at loads just above idle, i.e ~1200rpm with 'some' load. But above posts insinuate it actually can/should come on at about 3000rpm and off at 5400rpm?
Anyone done a dyno with it on/off between 1000rpm and 3000rpm?
  • 1 year later...
I have some info for you @LaurelPWR,
Rb25de Neo cam gear is 30degrees advance
Rb25det Neo cam gear is 20degrees advance
N/A cam gear is indicated by a green dot on the front face.
I now have my own question, has anyone ever had issues with vct cam gear seal leaking when externally feeding vct, eg supplying it too much oil.
Is it required to restrict Vct feed line with the neo system? Engine is Rb30/25 Neo.
No never had a problem with oil leaking, I installed new seals at build. I did not use any restriction either.
@GTSBoy im more worried that its flowing too much oil to drain back rather than pressure, may be pressurising the area behind the cam seal because it cant evacuate the oil quick enough and therefore pushing past my brand new seal, does anyone know the fluid path of the vct well to share their info?
But what flow are we talking about here? This is not powered by flow. It is powered by static pressure. The oil doesn't have to go anywhere. There is probably a little flow channel somewhere to allow it to purge air out, but it is supposed to receive lots of oil pressure because it is oil pressure that pushes the actuator. It's not like a turbo where the oil just has to be there and any extra pressure will push it through the seals. Pressure is desirable here.
@GTSBoy im not entirely sure how the fluid dynamics work but i do know there are 4 vents around the gear that exit the gear, surely excess oil would have to go somewhere?
You're still working on the assumption that there is such a thing as "excess oil". I would argue you want full engine oil pressure available in the actuator and that the flow away from there through the bleed holes is whatever that pressure will cause applied to that cross-sectional area.
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
