Hi
$37,500 NON NEGOTIABLE
Call me on <removed> if interested
Nothing to spend on this car
Since ownership I have installed MCA race prime coilovers with 14kg front 8kg rear springs
Performance friction 2 piece front rotors
Performance friction 11 pads front and rear
HEL braided lines
Winmax race spec brake fluid
New 18x10 +15 wheels
Hankook RS4 tyres 275 35 18
Varex muffler
Battery
MODIFICATIONS WHEN I BOUGHT IT (completely legal - permits for everything including externally venting blow-off valves).
· Nismo 320KM Dash
· “A” pillar gauge cluster with HKS boost gauge and exhaust temp gauge’s.
· Momo steering wheel, boss and gear shifter knob.
· Trust front bar, skirts and Veilside rear bar (with low drag underbody shielding and brake cooling deflectors).
· Exeedy twin plate clutch and flywheel.
· Exhaust – full 4” stainless system, with custom cat and Xforce stainless 3” 2 to 1 y piece from dumps.
·  Garrett Steel wheel turbo’s, Extrude honed and ceramic coated manifolds, Xforce stainless dump pipes with separate waste gate pipe work.
· Engine Gear train - OS Giken Adjustable cam gears,
· Tomei Cams installed and tuned
· Tomei dual feed billet fuel rail, 700cc Sard injectors Sard rising rate fuel regulator with pressure gauge and Sard hi-flow in-tank fuel pump.
· Silicone Splitfire coil packs
· Crank case ventilation -  Rocker cover baffles, Cusco primary and secondary oil catch cans.
· Blue ceramic coated rocker covers and valley cover.
· PWR 57mm radiator
· Earls front mounted engine oil cooler with thermostat, remote mounted engine oil filter housing, Earls stainless braded hose & fittings.
· HKS front mount intercooler
· HKS Aluminium intercooler piping.
· HKS twin Sequential blow-off valves.
· Custom intake piping.
· New upsize Z32 airflow meters.
· Apexi pod filter, aluminium AFM adaptors and carbon fibre filter separator housing.
· Cusco master cylinder brace
· engine brace/dampener
· Apexi Power FC hand controller
· Greddy Electronic boost controller
· Apexi turbo timer
· Vehicle Dynamics Processor installed – ECM with G-force meter
· Immobiliser & Alarm system.
· Pioneer in dash CD/DVD/Sat nav
https://www.sau.com.au/forums/topic/474020-r33-gtr-v-spec/
  • 1 month later...
