I have used the import/export functions to update the CDDB information after loading a CD into Music Box,  this is a fairly simple process, but I see there are menu options for updating the CDDB data over the internet.
Does anybody know how I can get the car connected to the internet?
Can I create a wifi hotspot on my phone and connect via that, or can the car connect to the internet through Bluetooth?
Or is the internet connection one of those proprietary things that only work in Japan in conjunction with Carwings etc?
2010 370GT coupe
https://www.sau.com.au/forums/topic/474075-cddb-update-via-internet/
No internet connection available for our AV systems dude. That's just the way it is.
While I'm not inspired by CDDB for anything, I'm actually building my own navigation and music source in a little Gigabyte i7 NUC (hand-sized mini computer), which will have a Garmin GPS antenna plugged into it. The external DAC will plug into one of the other USB ports to convert to decent analogue audio to feed into the Aux input in my console, while the HDMI feed will be converted through a composite video converter (a quality one though) to feed the video Aux input.
Then the next step will be to adapt the touchscreen's serial output to feed the NUC as a mouse, effectively. That should complete my navigation and audio solution. I've had enough of Mirrorlink devices to connect to mobile phones because quite frankly, mobile phones shit the bed too often, battery issues arise, etc.
So yes, it will then be possible to have internet connectivity in my car to take advantage of. :)
Have you got any specs on the touchscreen output?  I hadn't heard of that.
I have a Orange Pi that I might be able to configure for suitable video output, it could be entertaining to put it in and see what software ideas I can come up with.
Also do you have any specs on the video resolution, framerates etc?
I believe the touchscreen panel is a 4-wire serial but that's the last step in the homework I intend to do and develop some kind of sharing switch for, in the event that I want to use the touchscreen to dial a number on the handsfree (rarely the case).
I don't have anything about the video resolution, though I assume being from Japan, it will be the typical NTSC-J standard, which is still 525 lines, 60Hz refresh. Even if the converter you find only does NTSC-M, the only significant difference is the colour temperature in which it operates (9300K vs 6500K). Not really a big deal when you're going to be displaying maps on it.
Edited by The Max
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
