Hello, so i have my aftermarket coolant gauge wired to an sensor in the upper hose, the 2 wires can be seen going into the sensor, but I want  to use the existing port that is for the stock coolant gauge. The problem is there are 2 wires going to the sensor i have now in the upper hose, but only 1 going into the stock location where i want to wire my aftermarket gauge too. What do I have to do to wire it? I dont think the stock sensor is a 1/8th npt size either? (pictures below)
Thanks for any help
IMG_0950.thumb.jpg.e037045f9a66ce8ec51e9335c43db0a9.jpgIMG_0951.thumb.jpg.58a1612b0ed308eb097ecd9d374d6a2d.jpgIMG_0952.thumb.jpg.f86cea644009dfd035f08f4ed572beae.jpg
11 hours ago, GTSBoy said:
Aaahhhh....take the single wire temp sensor out at your great peril and misfortune.  That one is for the ECU.  The 2 wire runs the dash gauge.
Ohh , I was told the single was for the gauge! Thanks for the clarification
Now I could be wrong, but I would have bet 5 bucks the single wire is the gauge sensor.
Based on this train of thought :
old cars had single wire for gauge, then efi came along and there were 2 sensors. I just assumed single is still for gauge. If I am right I am owed 5 bucks. Ig wrong the bet never officially took place.
  • Haha 1
Yea I thought it was the single too, that’s what someone else said too... that’s why I’m confused on the wiring
1 hour ago, smart_garrett said:
Ok, so can I just ground one wire from the new sensor and splice the other one into the old sensor?
I'm not sure as I haven't installed an aftermarket sensor. I guess you could try it. Do you have a separate temp gauge (in case the stocker ones dies)?
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
