Selling engine as I have sold the project car it was in.
Standard late model r31 bottom end. Genuine under 90k km.
R34 gtr rb26 head. Was reconditioned with new valve guides and 3 angle valve seats and surface grind.
Standard cams as I wanted a smooth idle.
ARP head studs, new head gasket
Hks 750cc injectors.
Block has brand new genuine vl turbo oil pump, all gaskets and seals, timing belt and tensioner kit, n1 water pump, tomei oil restrictor, mod to sump to allow external oil pressure adjustment.
Modified plenum with Vh45 throttle body. Removed from car. Hasn't been fitted with a turbo .
Have a video of it running. Cam covers not included as they were painted by our kids.
sell for $5000 ono or swap for something of value. Located 2287 nsw
Also have turbo and manifold that was running on my r34 gtr. Made 380 kw. Can include for a deal for serious buyers.
painted by our kids. Edited by Griffin
Typo
https://www.sau.com.au/forums/topic/474111-r32-gtr-parts-gtr-festival-meet/
I'm clearing out the shed and have the following r32 gtr parts I'll be selling.
IM GOING TO EASTERN CREEK 26th of MAY for gtr festival.can bring items with me.
Gearbox
Rear cradle complete diff/ brakes shafts etc
Radiator
Steering rack
Steering column with ignition and key
Engine loom and ECU
Ac compressor brake master/ booster
Clutch master/booster and lines
Front hubs
R33 turbos less turbine housing x2
N1 turbine housing x2
Flywheel
M's pod filters/ adapters
Flywheel
Stock intercooler
Gearbox crossmember
Turbo manifolds and oil / water lines and associated plumbing
Abs pump
Steering wheel needs recovering
Intercooler piping
Front subframe
Open to realistic offers as no need for it.
Edited by Griffin
Added
Selling the following brand new parts as selling projects.
-MLS metal head gasket
- Hastings rings. 86 mm rb30
- king bearings. Standard sizes suit rb30 . Main +big end.
-ARP head studs suit rb25 rb30.
All unopened brand new. Cost around $1100 from local engine builder.
Asking $700.
IM going to gtr festival tomorrow 26/05/2018.
Can bring with me.
IMG_20180525_121812547.thumb.jpg.3d27e63b72b53b3dbca254c90103d95a.jpgIMG_20180525_121735114.thumb.jpg.18824176406a73290e12af5f60672f81.jpgIMG_20180525_121513486.thumb.jpg.eebca3ec8cf166d0f0741846ed1a639c.jpg
  • 1 month later...
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
