Hello everyone! Nathan here, got myself into a massive project in july '17 buying an r32 coupe with an rb20det, r33 gearbox and unfortunately a rooted chassis rail! Going for a road going first track car, i bought a bare shell and the job of swapping everything over, and finding all the dodgy suprises left from the previous owner, has begun...20170703_182916.jpg20170702_141952.jpg20170825_170005.jpg
As you can see the new shell has been hit in the rear but to my rescue a smash repairer and mate helped me straighten the rear out, remove the beaver panel and steal the rear out of the now parts only car!20170823_182733.jpg20170826_143908.jpg20170927_151028.jpg
With that sorted and a new gtr front end purchased, the next job to tackle was the engine bay, a quick tidy up removal or surface rust and respray was done by myself in my shed while saving for more parts and to prepare for the big swap. 20171108_180110.jpg20170903_114128.jpg20180503_114450.jpg20180504_155141.jpg20180504_165441.jpg20180510_092212.jpg
With all that done and ready to go we recently started taking the engine out, inspecting what I need to replace and transferring all the bay equipment to get ready for the rb20det 20180526_090217.jpg20180526_102046.jpg20180526_160013.jpg20180526_155931.jpg
Still a bloody long way to go and this is my first big project like this so I am enjoying the education and the opportunity to really get my hands dirty and make the car my own.
Please let me know what you think and what advice you have i still need a lot of parts like a speedo cable to match the r33 rb25det box to the r32 cluster, bellhousing bolts (as 3 were simply not there haha) and ideas for the customised gearbox crossmember in reference to the qld registration. Also thanks to the previous owners low life addiction... a better sump haha. Peace everyone [emoji111]
  • Like 1
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
