Garage clean up time:
All items came from an R34 GTT Skyline 5sp manual with Hicas and may fit other models,
I'm happy to post some of this stuff but would prefer local pick-up,
Located Newcastle, NSW.
- OEM front lower control arms
- OEM front upper control arms
- OEM Castor arms
- OEM rear lower control arms
- OEM rear - front upper camber arms
- OEM rear - rear upper camber arms
- $250 for the lot or I can separate.
All arms would suit new bushes and ball joints, no visible signs of damage to the actual arms, only the ball joints (pictured),
- OEM steering wheel w/ airbag - worn - $50
- OEM Dash cluster w/ 230251kms - missing a globe or 2 - $100
- OEM triple cluster - $75
- OEM 5sp manual shifter - $30
- OEM diff centre with 5 bolt flanges - suits rebuild - $100
- OEM rb25det neo oil filler cap - $15
- Turbosmart dual port BOV w/ rb25det neo flange - worked fine before removal - $100
- OEM Airbox - no filter - $40
- Solid metal turbo intake w/ silicone joiner
- $30
- OEM radiator hoses - worked before removal many moons ago - $15
- OEM rb25det neo throttle body w/ tps and tcs- tcs does not work and throws a code on a factory ecu - $40
- Oil catch can of unknown brand or origin - removed many moons ago - $20
- 6 x OEM rb25det neo injectors w/ spare o-rings - purchased in working order for fault finding but never used - $75
- HKS GTRS turbo charger - wasn't holding much boost, crack on the rear housing and has some shaft play -- suits rebuild -- $200
All prices negotiable and I'm happy to help the right buyers out.
Happy to answer any questions or take more pics.20180527_122229.jpg20180527_122237.jpg20180527_122241.jpg20180527_122245.jpg20180527_122248.jpg20180527_122252.jpg20180527_122300.jpg20180527_123947.jpg20180527_123956.jpg20180527_124000.jpg20180527_124009.jpg20180527_124014.jpg20180527_124017.jpg20180527_124022.jpg20180527_124026.jpg20180527_124030.jpg20180527_124034.jpg20180527_124100.jpg20180527_124123.jpg20180527_124218.jpg20180527_124222.jpg20180527_124239.jpg
https://www.sau.com.au/forums/topic/474132-er34-parts-garage-clean-out/
Hey mate, what size is the metal turbo intake? Does it have the Bov return & vaccuum hose connectors on it?
Cheers
Hey mate, it's 75mm (3inch) both sides but has a silicone step-down to a 2.5 inch. And unfortunately it doesn't have any other inputs or connectors. She solid
Currently set up to recirculate but also comes with the trumpet for VTA applications.
Worked fine before removal, only changed it because I went with a HKS bov.
Current mounting flange is for a rb25det neo, can be changed.
$100
$100
Happy to post.20180531_165637.thumb.jpg.7790f4f4df93f83d18c4888640fa35a6.jpg20180531_165700.thumb.jpg.654a81cd16128199ff4b740ccbd94edd.jpg20180531_165709.thumb.jpg.67bf4725c38f61fb9f5fdb1623debb67.jpg
BOV SOLD
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
