Hi Guys.
So in pursuit of making my RB26 a well even and smooth running engine I've done a lot to it, putting all the best bits on it
I'd like to know some more information on the Nismo and Greddy manifolds.
The question is do they make the engine run smoother and respond better.
The theory is these try to get the airflow to each cylinder as even as possible, especially fixing the 6th lean condition.
Speaking to many tuners about it and a lot are in disagreement, most say with modern ECU's you can adjust the individual injector to ensure a proper A/F mixture so these manifolds won't help.
My theory still is though if one cylinder is getting less airflow, for that power stroke it makes it is making less power and pushing down with less power down the crank, and the engine won't ran as smooth.
So my first question is, while the theory exists, in practice how much of a difference does it make - I don't mind spending the money if it makes some improvement in your guys experience if you've ever done back to back.  I know a lot of SR guys notice improvements when they put aftermarket OEM replacement plenums on but have not heard so much talk with RB26's
Much reading I done mentions that this helps get the twin turbos working more evently, I'm running a single though.
The 2nd question is, Greddy or Nismo, big price difference.  And which ones can or can't be replaced with the engine in, apparently the engine needs to come out for these to be fitted.
The Greddy one i wonder why is a 2 Piece.
I'm also considering, the Hypertune multi TB plenum
Edited by RB335
https://www.sau.com.au/forums/topic/474139-rb26-oem-v-greddy-v-nismo-plenums/
theres people making 900+hp on a stock plenum. not much point in changing it unless youre chasing four figures plus.
... or want to tidy up the engine bay and make it less of a headache to work on. On the downside, youre changing oem stuff that works just fine and increases possibility of failure
The theory of uneven power strokes making the engine less smooth doesn't really hold water.
And the idea of tuning out lean cylinders only works if you put 6x TCs or 6x O2 sensors on the runners to see the effect otherwise you're "fixing" something with no evidence.
  • Like 1
nothing fits better than or fits like oem. theres larger plenums take up more room and are harder to work on. not to mention they change the angle or position of the outlet so you need to change cooler piping as well. aftermarket is not always better. and GTSBoy is right.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
