Hey guys, im new to skyline Australia and i would like some help.
My skyline r33 is losing power when i flat foot and the rpm reaches 5000rpm or so. Recently the problem has seem to evolve and make the car die out past 5000 rpm and what i mean is, the car is still on but there is no power what so ever past 5000. I've had this problem before except the dying out part and i fixed it with AFM. I have bought 2 AFM's and put them in the car and reset the ecu, however the problem is still there but the car dying out problem seem to be gone. Does anyone have any advice on what i can check next please. Im a student so i dont wanna go out and spend more money for nothing.
My car only has a few mods: (STOCK ECU + BOOST-no boost controller)
1.Spitfire coils packs
2.FMIC
3.After market fuel pump KEMSO 340LPH
4.Exhaust system turbo back
5. Iridium sparkplugs that i replaced about 6-8months ago. (Have not touched the gaping)
Tomorrow i will check the coils and spark plugs, but is there anything else i can check? Ive also checked previously for air leaks but found nothing.
Can timing belt be an issue? and o2 Sensor?
Thanks!
Rany
https://www.sau.com.au/forums/topic/474144-dying-at-5000rpm/
Partially collapsed cat or muffler or flattened exhaust pipe can do that,  had a Falcon that started doing this at higher revs then one night on the freeway it fired a blazing ball of muffler packing out the tailpipe and became much louder.
14 hours ago, wildeagle44 said:
Maybe bypass the knock sensors? Could be pulling timing.
Does it happen in every gear?
This time it is happening every gear. I cant flat foot on any gear from 1 to 4 so i'll check it out. would you know where their located?
Thanks mate
12 hours ago, BBGTR said:
Sounds like the igniter module, they sometimes break down at higher revs when they get old.
Thanks mate i'll have a look into it today.
The data sent from the car’s oxygen sensors to the computer helps it adjust the air-fuel mixture for optimal operation. If a sensor is bad or failing, the computer won’t be able to adjust this mix correctly. Also a clogged fuel filter can cause similar symptoms. Combine the two and you are in a world of pain. A new fuel filter is a cheap starting point buddy.
Thanks for the reply Rusty. I have bought a new 02 sensor. Im gonna change it, if it fixes the problem im happy if it doesnt then i will just changed a part that is over 20 years old. I will also buy a new fuel filter since my 1 is still the original im sure.
    • So, they simply stick out too far because very wide + very low offset (at the front). At least it's up nice and high so they shouldn't bang into the car too much.
    • Since this is the page where i found myself while searching for wheel fitment, i will add the ones im looking to replace too. Fenders arent rolled, so in big bumps they touch the tire (tires could be narrower). no any adjustable arms, so the camper is what it is (dont know). Wheels: 5ZIGEN Fireball Front: 18x9.5 ET12 - 245/40 Rear: 18x10.5 ET25 - 285/35
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
