cfield Posted May 29, 2018 Share Posted May 29, 2018 (edited) When I first purchased my Oct 1991 R32 GT-R's air conditioner was great. Although now it's blowing fuse # 10 (10 amp). As soon as I turn on the A/C, it blows the fuse. I followed the steps for self-diagnosis without any error messages found. Here is the fuse that is blowing: The major load on that fuse is the magnetic clutch for the compressor... Any idea if I can simply replace the magnetic clutch? I can't seem to find one anywhere (I'm in the U.S.). Or, does the whole compressor need replacing? Edited May 29, 2018 by cfield Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/ Share on other sites More sharing options...
GTSBoy Posted May 29, 2018 Share Posted May 29, 2018 Go ask a car air-con place. That's what I would do here in Oz if I weren't surrounded by Jap import spares shops. Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7876719 Share on other sites More sharing options...
rat32r Posted May 29, 2018 Share Posted May 29, 2018 Hey mate had this happen to me long time ago ended up being theA/c electromagnetic clutch.Had a spareCompressor that had lowSuction an robbed the coil from it.Before you doAnything try pulling the plugOff the compressor and see if it still pops the fuse as you may have a wiring short Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7876797 Share on other sites More sharing options...
BourneToLive Posted January 2, 2022 Share Posted January 2, 2022 I’m blowing the #20 AC 10A fuse at the bottom row in the middle. Does anyone know what that could be? Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7959263 Share on other sites More sharing options...
TurboTapin Posted January 2, 2022 Share Posted January 2, 2022 On 1/2/2022 at 12:09 AM, BourneToLive said: I’m blowing the #20 AC 10A fuse at the bottom row in the middle. Does anyone know what that could be? There's a few things on that fuse with the highest load being the AC condenser fan. Take a look at the electrical drawings. Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7959278 Share on other sites More sharing options...
GTSBoy Posted January 3, 2022 Share Posted January 3, 2022 Disconnect everything on that circuit. Replace the fuse. Plug the disconnected things back in one by one until the fuse blows. Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7959281 Share on other sites More sharing options...
BourneToLive Posted January 3, 2022 Share Posted January 3, 2022 (edited) On 1/3/2022 at 5:15 AM, TurboTapin said: There's a few things on that fuse with the highest load being the AC condenser fan. Take a look at the electrical drawings. I traced the AC condenser fan’s wires to this green connector on the left side of the radiator and it had a sketchy looking red wire in it that looped. I’ll attach some pics so you can see. The original plug was right next to it, so I just plugged it back in. I have tried to see if it fixed the blowing issue because I don’t have anymore 10A fuses left lying around. Lol. found a 10A and it still blew it. Edited January 3, 2022 by BourneToLive Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7959313 Share on other sites More sharing options...
TurboTapin Posted January 3, 2022 Share Posted January 3, 2022 (edited) On 1/3/2022 at 3:25 AM, BourneToLive said: I traced the AC condenser fan’s wires to this green connector on the left side of the radiator and it had a sketchy looking red wire in it that looped. I’ll attach some pics so you can see. The original plug was right next to it, so I just plugged it back in. I have tried to see if it fixed the blowing issue because I don’t have anymore 10A fuses left lying around. Lol. found a 10A and it still blew it. That is the thermoswitch connector that controls the ac(overheat) fan, not the fan motor itself. The jumper is there so the fan runs constantly. Do not put it back. What's the condition of your rad, shroud and rad fan? This may have been done to test your ac fan or alleviate overheating issues but that's a seperate issue. Edited January 3, 2022 by TurboTapin Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7959317 Share on other sites More sharing options...
BourneToLive Posted January 3, 2022 Share Posted January 3, 2022 They seem fine. But I don’t recall the radiator fan ever turning on, and my coolant temp is 78C on average. Link to comment https://www.sau.com.au/forums/topic/474151-r32-gt-r-ac-not-cold-blowing-fuse-10/#findComment-7959319 Share on other sites More sharing options...
