Hi guys, just thought I would put up some pics of a fun project I am building. It is a exoskeleton-type chassis that will seat two and is mid-engined. The chassis is not yet complete in the photos, and I am busy adding triangulation and making changes as I go. Won't be using STI wheels, those were just for "full effect" ?
For now this is being built in mild steel as-is a prototype that needs changes made as issues arise during manufacture. Once i am happy with the final specifics and approved for road use, I will build another from much thinner wall 4130 chromoly. I am a Fabricator, so the welding shots were compulsory!
This car is running an Alfa Romeo 2.0 engine, which I have also developed a turbocharger setup for, and will make between 250-350hp boost-dependant. This will weigh about 550-580kg. I also have a 370z engine that I may twin-turbo and throw in the back, which would be quite hilarious.
Depending on my workload, I hope to have this thing running in the next few months, and if there is any interest I will keep it updated as things move along. Hope to do some roll racing and circuit racing in the future at SMSP and Wakefield
  • Like 2
https://www.sau.com.au/forums/topic/474167-custom-tubeframe-ghetto-beast/
1 hour ago, Leroy Peterson said:
Very nice.
What transaxle do you plan to use? Looks pretty tight in the back
There is plenty of room for transversal setups. The current engine as mentioned is Alfa Romeo using a FWD gearbox. When I do the next chassis with the VQ37 I will use a Maxima manual FWD gearbox and shafts, at least that is what I am planning
Do you know if the RWD VQs will happily bolt to the FWD VQ gearboxen?
I was going to ask "since when has there ever been a VQ powered manual Maxima?" and then I looked on Wiki and was surprised to see that Nissan actually made some.  Seems totally out of character/market segment for a Maxima though.  I wonder how many are actually out there in the wild?
To be honest I would assume there would be some adaptation necessary, however the standard VQ bolt pattern should carry over without issues, then the "fun" would begin to make it all work. I feel the gearbox itself would be quite robust, as it is designed for the VQ engine and to carry a big car that would potentially be full of passengers and a big trailer hanging off the back. No idea how many were produced, but I will be beginning a search in the near future
So I decided that the Alfa Romeo engine would be better served in my Formula 3 (as it was an engine originally used in the series) and have decided to install a Lexus 4GR-FSE engine, stroked to 3.5L and using a single turbo setup. The second chassis I make will probably be intended to look a lot more like the Ariel Atom and that will use the VQ37 engine that I have stored away.
I advanced with one of the manifolds today, using a narrow angle configuration for the runners, which will promote scavenging. The two banks of manifolds will merge together and the turbo will sit above the transmission.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
