long story short i blew my standard gear box, but the way it happened seems odd...
first i went for a hub dyno tune in rear wheel drive, so i pull the transfer case shaft out,
when on the dyno the lsd was fighting each other so much so that the car wouldn’t rev smoothly and reading allot less power than it should. i know this because out of the three pulls on the dyno one of them was smooth,
first pull the diff was fighting itself and read 300kw,
second pull the diff worked and read 500kw, third pull 300kw again...
he checked the reading of each hub and the two sides were reading very different power figures??
the car always drove fine?? the tuner said the diff is no good, “this normaly happens when a diff is wearing out” one wheel gets more power than the other
here are the reasons i don’t believe this too be true.... the diff had new gears and checked recently, the diff guy even said “i tightened it up abit” in other words it should be more “limo” than standard
now, is there a way the active lsd works on the dyno?
i rang one diff place and he said by you taking out the front shaft your confusing the active lsd pump "it sounds like an active lsd pressure problem, probably caused buy you removing the shaft"
the guy that did the diff is pretty good at what he does, i don't think he got it wrong
now i'm driving home in rear wheel drive (shaft still out) on low boost and i can feel the reving out pretty slow (it never did this in four wheel drive) so now the diff is fighting itself on the street too (for the first time)
i give it a hit in second and the gear box breaks ( mind you the box held 1000hp before that) yet it breaks in rear wheel drive at 65% of that power
what you think?
Did you pull the air bleed wire and push the brake pedal 5 times to put the 4wd computer into RWD mode as well as removing the front shaft?
Sounds to me like there was 200kw of power turning into heat somewhere, one rear wheel rotating faster than the other is going to heat up your diff real quick isn’t it?
For me the question is what the 4wd computer was trying to do, when it detects wheel spin it shoves torque to the front (ie locks up centre diff more), hence the question about setting the computer into rwd mode.
I wonder what it does to the A-LSD lock up in this situation, would it go up, or down. As mentioned by R.3.2.G.T.R in normal operation more TPS = more alsd lock up (and more cornering force = more alsd lock up too), but I wonder if it was freaking out and going into a failsafe mode (the centre diff failsafe is 20% lock from memory).
Perhaps you overheated something. Maybe a hub dyno aint so good with A-LSD.
no i didn’t do that
there was no light on the dash
you think that would have caused it
like i said, the car always drove straight under power
so putting it in RWD mode is a must?
(btw i did see the front torque gauge go too max at times)
I’d say most people on this forum with 500kw have replaced the A-LSD with a normal LSD like nismo etc, and possibly broken gearboxes too.
The thing about the A-LSD is that it locks when commanded to by the attesa ecu, not from torque from the engine like a regular lsd. A-LSD operation also relies on hydraulic actuator lines not leaking, or needing to be bled.
Dunno if you ‘caused it’, but the A-LSD not being locked on hub dyno sounds bad IMHO.
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
