Hi, I've been searching with no luck around the web, I'm trying to find out pinouts on the f3 plug for an engine conversion
if anyone can have a look or trace the ecu plug to the f3 plug
just need vss speed/ revs/mil / dash temp and ignition might aswell put fuel pump for future reference for others
just doing a engine conversion  sold the main engine loom with the engine
I am pretty sure yellow/green is speed and yellow/red is rpm  not sure on mil light or temp any help would be wonderful thanks
https://www.sau.com.au/forums/topic/474175-f3-pinouts-r33-s1-wanted/
Thanks Rusty, I've already got that the mil light changes from a orange with black stripe I'm thinking it may turn into orange but that's going on S13 wiring n it could be any colour really I'll grab a test light on the weekend and post a pinout ... Also anyone know if the Speedo needs a AC wave like the S13 or if a square wave is fine
AFAIK the output from the skyline box is an AC wave that is converted by the cluster to an output usable by both speedo and ecu. The speed signal starts out at the speed sensor as a +/-1 volt sawtooth (roughly AC) signal generated by the rotation of the sensor.  The 2 wires associated with this go to the cluster, where the speedo reads it and displays it.  The speedo head also converts the signal to a 0-5v square wave pulse that it puts onto the bus.  The ECU looks for that signal.( Thanks to GTS Boy for this info in previous post)
You got so lucky i'm removing the head off of my 25det today so here are some pics, the plug on the harness is two pin not three the additional black is in the second pic and is earthed to the igniter. The two in two pin plug are white and black20180601_105128.thumb.jpg.0929a6f553ade37f5087763e98c80241.jpg
Edited by Rusty Nuts
The white is power 12v+ and goes to every centre pin on the coil plugs. The various pinks with stripes (except cyl 1 which is black with pink stripe) go to pin left of white when looking at rear of coil plug. The black goes to the right. The black and Red in your diagram is probably the timing light breakout ,check for continuity with No.1. Happy to help so ask away, I drove myself mad wiring a Neo into a Series 1.
    • You have (externally anyway) a lot of patience!  At the very least your patience has rewarded you financially even if you decided you were over it!! I only just read your first experience of seeing the car, that would have been amazing!  Well documented too! It must be exciting knowing there's only 10 months left until you can get it on a boat and on it's way!!!???
    • Yeah, that's when. I guess you could say I'm as patient as I am foolish(or just a masochist?🤔). I've strongly considered throwing in the towel and calling it all quits many times, and have almost done so. It's a first-world problem for sure, but I've had a pretty rough go of it, as well as other factors; hoping something good comes of all this; it has to. It definitely is half the price of the ATS and performs great, but I'd like to try something different for once. I've sampled the ATS in a friend's 32 and it's solid👍
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
