Dose Pipe Sutututu Posted June 4, 2018 Share Posted June 4, 2018 Hey All, As you know, this is one mighty powerful ECU capable of running full flex, anti-lag, launch control, traction control, etc. Also has engine protection features, MAP predict for transient throttle - extremely powerful ECU. I have used it in my car and have tuned other cars running this very ECU. As my needs have changed, I am upgrading to an ECU that supports more features so this bad boy is up for sale, comes with: ECU itself Internal connector & harness (with quick release connectors for flex input, additional wheel speed sensor input, etc) USB port has been repaired and loads of glue has been applied on it (common issue with these ECUs) Price: $800Location: Canley Vale, NSW Will remove from car after it has been demonstrated working, and will give you a bunch of other tunes too. Link to comment https://www.sau.com.au/forums/topic/474196-fs-syd-adaptronic-select-440-plugin-for-r3233-gts-t-r-800/ Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 6, 2018 Author Share Posted June 6, 2018 Just a heads up, will be removed in a couple of weeks from the car. If you buy it now-ish at least you can see it running. Link to comment https://www.sau.com.au/forums/topic/474196-fs-syd-adaptronic-select-440-plugin-for-r3233-gts-t-r-800/#findComment-7877515 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 7, 2018 Author Share Posted June 7, 2018 Link to comment https://www.sau.com.au/forums/topic/474196-fs-syd-adaptronic-select-440-plugin-for-r3233-gts-t-r-800/#findComment-7877629 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 14, 2018 Author Share Posted June 14, 2018 BUMP Great upgrade for PowerFC owners Link to comment https://www.sau.com.au/forums/topic/474196-fs-syd-adaptronic-select-440-plugin-for-r3233-gts-t-r-800/#findComment-7878214 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 25, 2018 Author Share Posted June 25, 2018 Need an ECU better than a PowerFC or Nistune for your R32/R33/R34 GT-R or R32/R33 GTS-t ? Look no further! Link to comment https://www.sau.com.au/forums/topic/474196-fs-syd-adaptronic-select-440-plugin-for-r3233-gts-t-r-800/#findComment-7879121 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 3, 2018 Author Share Posted July 3, 2018 SOLD New owner will have much fun many awesome with anti-lag and flat shifts pow pow Link to comment https://www.sau.com.au/forums/topic/474196-fs-syd-adaptronic-select-440-plugin-for-r3233-gts-t-r-800/#findComment-7879931 Share on other sites More sharing options...
