Hey All,
As you know, this is one mighty powerful ECU capable of running full flex, anti-lag, launch control, traction control, etc.
Also has engine protection features, MAP predict for transient throttle - extremely powerful ECU. I have used it in my car and have tuned other cars running this very ECU.
As my needs have changed, I am upgrading to an ECU that supports more features so this bad boy is up for sale, comes with:
  • ECU itself
  • Internal connector & harness (with quick release connectors for flex input, additional wheel speed sensor input, etc)
USB port has been repaired and loads of glue has been applied on it (common issue with these ECUs)
Price: $800
Will remove from car after it has been demonstrated working, and will give you a bunch of other tunes too.
Just a heads up, will be removed in a couple of weeks from the car.
If you buy it now-ish at least you can see it running.
Need an ECU better than a PowerFC or Nistune for your R32/R33/R34 GT-R or R32/R33 GTS-t ?
Look no further!
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
    • Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
    • The suspense is killing me lol.  Are you going to buy a flex sensor, then add the 98 tune to your current tune?  It sounds like your just going to delete the current tune and re-tune the car on 98 =/ If you've only known your car on e85, I don't think it will be long before you install the flex sensor and go back to running e85 when its available lol.
    • Currently on an e85 only tune, but I barely get 200km from a full tank. Makes going for longer drives difficult, especially when u leave Melbourne metro as there aren’t many united servos, hence why I’m thinking of going more of a 98 setup.    And yes the smell lol. Any drive afterwards I need to have a shower and wash all the clothes I was wearing, it’s like someone made a Calvin clown e85 perfume and sprayed it all over me haha
