Hey all,
Thought i had a build thread for my 32 but cant see it so maybe not, anyway.
Bought (becuase it was cheapppp) what can only be described as the worst looking r32 around. Ugly kit, check. Ugly white painted interior, check. $2 bucket seat, check. on LPG, yes LPG! check.
i wanted a project, so i bought it for cheap and brought it home
  • Like 1
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/
Since i killed the front bar, i found a GTR front bar and lip
Plus for now also got a standard r32 bonnet
Also removed everything to do with the LPG, thankfully it wasnt dedicated LPG. Just had to remove, fill a few holes here and there and bingo
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877417
a pair of excellent nic 32 gtr seats came up for cheap so replaced the crappy $2 recliners in it.
Plus started to remove anything painted white inside the car! and also changed the steering wheel to one i had lying around
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877419
The rb20 still runs fine, so removed to give it a bit of a tidy up and new gaskets etc etc. not looking for this car to be a power house, always wanted something that looks nice when you pop the hood. plus i already have my track car for speed.
So while the engine is out im tiding up the engine bay. removing all the HICAS, Putting the Battery in the boot, and hiding the fuse box. Will also change a couple things like the washer bottle, over flow etc. Will then fill holes, smooth and paint
Edited by Adz2332
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877423
I had a look at the Pandom kit for the 32 and didnt like it... so instead i did a thing.
I bought genuine rocket bunny flares front and back, same as the car below, from streeter.
Now not 100% sure ill go this way but they are sitting there
  • Like 3
https://www.sau.com.au/forums/topic/474206-r32-gtst-build/#findComment-7877426
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
    • There's another sensor that sits inside the evaporator, that's a C U N T to get to, but can be done without removing the entire unit. Usually it's not the sensor that dies but the actual capacitor in the circuit (part of the plug that dies).
    • Putting the climate control CU into diagnostic mode is independent of the ECU. You just have to do the dance prescribed in the manual. No, I do not know what the dance is. I have an R32, so use the dance in the R32 manual. On older cars, I would have said "no, the ECU should not affect whether the A/C works".... but for an R34 that might be wrong. I don't recall the detail, but there was extra mods required to make my R32 A/C work against the R34 ECU. The R34 ECU apparently gets involved in the running of the A/C more than earlier cars did. Theoretically, if the PFC is a true plug in, then it should just work the way that the original ECU does - wrt A/C. But there's always scope for them to have not cared. Nope. Pressure switch out = getting the fridgey out to pump the gas out before pulling the switch. The switch really cannot sense gas pressure unless it is up against the gas.
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
