I'm getting a really weird smell when I drive. I hope its the clutch but am not to sure It's hard to describe but tthe smell really reaks. I can smell it in the cabin and outside. its a weird smell though.
I cant really notice any slipping but i could be as the performance has felt pretty avergae lately.
Any ideas what it could be?
help!
JaFF
https://www.sau.com.au/forums/topic/47421-car-problem/
check yr brakes aren't glowing, could be a jammed on mc, but more likely to be a clutch.
A cat [furry type] thats crawled up under yr car and is cooking on the exhaust.
Does it smell like mums sunday roast?????...................lol
Also check yr grommets at the firewall, you could be leaking water in under yr carpet [mine was like that when I bought it, idiots had sliced open the grommets to run extra wires, and then didn't seal them up again.
https://www.sau.com.au/forums/topic/47421-car-problem/#findComment-958223
Thanks,
I had the brakes done a while ago. Some green colored kevlar, cant quite remember the name. But ever since they have been squeeling really bad. I thought they would wear in but they havn't. The only problem with that idea is that the smell has only been in the last week or so and the brakes have been in for months.
https://www.sau.com.au/forums/topic/47421-car-problem/#findComment-958282
also if it is the clutch should I get the exedy HD patrol clutch?
I have heard conflicting reports (yes i have done the forum search and read the posts) and most people say that it good and others are concerned that it would be rooted after a few high rpm launches.
What are some other cheapish clutch alternatives that would suit my car, 3" zorst, FMIC, 10-12 psi boost controller.
Hoping to get around 200rwkw eventually.
https://www.sau.com.au/forums/topic/47421-car-problem/#findComment-958410
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
