Mid-Week Update:
Attack the issue with the oil cooler lines and fittings. It now has the correct size AN fittings and all new black hoses. New mounting brackets on the oil cooler also adde d. The oil cooler will be mounted behind the intercooler and parallel with the car. Pics to come soon!
To add a little more to the upgrades I asked to have the "Twin Turbo" Divider Mod to be done.
Edited by Dewayne2121
  • Like 1
ECU and Flex Fuel Sensor came in. The ECU itself is very small and compact. Picked up the Plug and Play harness for the RB26. Got a bluetooth sensor also to run the Real Dash (or apps similar) on a tablet.
  • Like 1
  • 3 weeks later...
A lot of progress has been made on the build and here's an update:
The motor is back in the car and running flawlessly. No more oil leaks and compression checks across the board are amazing!
37679531_10214208858708029_5192286981765201920_n.thumb.jpg.e7a7bbcf3fddc1c124f37ef7a4802f6e.jpg
Wrinkle Black Paint really makes this look great!
37793926_10214208862588126_3375576413250781184_n.thumb.jpg.e58a46ec3a3deb41daaff590107c101d.jpg
Radium rail installed w/ stock injectors. Will place the new injectors in once we get the ECU Plug n' Play Harness.
37669685_10214208860468073_1630960723385384960_n.thumb.jpg.228c7178a53a3f3e76e25082c80e07a1.jpg
I love just admiring the new look on the intake side of the bay. Aeromotive FPR w/ pressure gauge. The  FlexFuel Sensor is also mounted on the strut tower. The Aeromotive fuel filter is the only thing not in the bay. It is under the car with the fuel lines.
37744613_10214208902389121_9139847279568486400_n.thumb.jpg.e2ce3f3200a47e2766fe4e317032c4d6.jpg
37661140_10214208862188116_8900761345146748928_n.thumb.jpg.6aaa4138ad2ea7b23a6861e8a08c142b.jpg
Oil cooler mounted w/ new lines
37734994_10214208897669003_2517890947686072320_n.thumb.jpg.a07bfebcef1aed08631151f552b72d27.jpg
37793926_10214208862588126_3375576413250781184_n.thumb.jpg.96b244b7841d32ff8eb94475c2551678.jpg
37686314_10214208902069113_6366844293931335680_n.thumb.jpg.3a6676c32b21c6e8cecff834d3910dda.jpg
This is the current ride height on the MeisterR ZetaCRD. Havent got a chance to drive so no review on the stiffness/comfort just yet.
37778094_10214208862868133_1216537172920762368_n.thumb.jpg.0d3fb2f1037bd04ca9d9ba51541d0822.jpg
37780316_10214208895228942_8638342756076355584_n.thumb.jpg.74f64c225a18ee0325ffc46a624d035a.jpg
Definitely gonna have to roll the rears with this setup.
37675584_10214208895428947_3866414235139440640_n.thumb.jpg.7e7e52becbeb78d39370b04b2d3fa39a.jpg
  • Like 2
Things Left:
Swap over 1000cc injectors and PnP clips
Delete MAFS (Turbo intake pipes 3" w/ compact filters wrinkle black)
Custom oil catch can behind battery made by Go-Autoworks. (http://go-autoworks.com/)
Order GM IAT sensor + use M12x1.5 to 3/8 male/female adapter
Install ECUMasters ecu, wire subharness (Wire in Wideband)
Tune Session Pump to E85. Gonna pull the 4WD fuse and see what it's capable of. Will update with more photos as they come in.
Nice build. Should be a nice little combo when done
there's a IAT sensor that bolts into the stock position and sticks out farther, with the faster response/open tip that i belive NZefi and Kudos motorsport has started selling, would recommend that for ease of install/neatness.
Im currently using NZefi's GTR Injector Resistor Delete at the moment so I will check this out and see. Thanks for the info!
  • 4 weeks later...
Quick update and just a visual of the build thus far...
So all the parts for the build have been ordered and on hand at the moment. My battery was constantly weak and we came to realize once there's a ton of random harnesses that are not being used. So to clean it all up Zack is going in there and getting rid of the unnecessary wires. Getting the seats done in perforated leather where the darker blue is on the seat and perforated Suede in the middle. Have suede e-brake and shift boot and will be covering the back seat with black carpet to match! Hope you're enjoying it so far!
Deleted the Stock Blow off Valves since going MAP.
Thoroughly enjoying the videos of the progress. Keeps the parts added and work done as receipts. Hope y'all enjoying them as well
  • 1 month later...
  • 2 months later...
Quick Update:
Custom Catch can installed to the right of the radiator.
1000cc injectors dropped in and idle set up.
Bought an AEM IAT sensor and moved it to the intake piping next to BOV.
Installed the seats back into the car (Need to install the Shift/E-Brake Suede Boots)
Car should be with the tuner before the month is out. Gonna do the pump gas then e85. Dyno and road tune for drive-ability.
Jun Style front lip installed and fenders pulled and rolled.
Also, got the old Optima Yellow Top battery out of their for a more suitable choice.931631418_12Jan2019.jpg.95caf0dd2ff57501b3d435d72f7baf69.jpg
  • Like 2
Pulled the car out of the shop for the first time in Months!!1943842887_OutsideMLK.thumb.png.218e58d5bd06f7ab5be695d9a1feb406.png
This is where we're at so far.
Quickly got the bumper and hood mounted back on Friday (January 18th) as the tuner called and was available to start on the pump gas tune. He picked it up that afternoon and worked on the tune and boost controller on the pump gas settings. Only 2 things came up.
  1. The power steering belt shredded for whatever reason (thinking just age). It has been replaced and all is well.
  2.  Lower charge pipe blew off at high boost/rpm... it may have not been tightened all the way after adding the bung, then swapping to wiring the bung. It's been reinstalled and all is well.
I was then informed Sunday (January 20th) that the tuner will be going out of town until the 4th. At that point I told him to bring me the car back so I can get the alarm taken care of instead of it just sitting idle. Got another Viper 5706v Two-Way Alarm to get put in since it was removed with all the harnesses that were tapped in the wires.
So, all that should be left is the gas swap and E85 dyno time.
I was sent a breakdown of the tuning bill so far.
This is what the tuner was able to accomplish thus fur:
3 hours tuning AFR and boost controller
2 hours of ECU tuning AFR and accel tables.
Now, I have to wait until he is back AND have the time to get it on the dyno and tuned... Almost at the finish line!
  • Like 2
  • 4 weeks later...
Sneak peak of the Dyno Tune session. This was dialing in the pump tune with a few pulls. Im in love with the BOV sound ! Sounds like the 2530s are trying to suck all the air in the room
Hey man, I've been following this since you first posted last June. I'm enjoying the way it's coming together for you and really looking forward to your opinions of both the ECU and the MeisterRs.
P.S. I'm just up the road.
Edited by Silverhks
The ECUMaster EMU Black has been a great product, but the customer service was not the best initially. I was on "backorder" which turned out to be a lazy employee who was procrastinating on making the RB26 plug N play harnesses. Once the harness was made, I was sent a SR20 pin out instead of RB26. Once that debacle was handled, there wasn't any issues as far as the product itself. They terminated the guy who had me on backorder for 2 months, but the motor was out of the car at that moment so i wasn't too upset. The tuner has no issues with tuning it and once we had the right pin out the systems on the car work flawlessly. I have to get back to you on the MeisterRs after I get it back and get a few weeks of behind the wheel time.
  • Like 1
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
