10 hours ago, Ben C34 said:
Bushed?
Make a bushing the size of the head stud hole with clearance for the stud in the hole, than install with sealant, stops any possible transfer of coolant. Bushed holes should have sealant on the head stud instead of arp lube
  • 3 weeks later...
  • 3 weeks later...
Block didn’t take long to get built and shipped. It landed this past Friday at the shop. It was a smooth and easy business transaction with the shop in Canada. Also the Unigroup camshafts came in. Got them fitted up and ready to send the head off to get cleaned and the New valves (guides and seals) installed. More to come....
  • Like 1
  • 1 month later...
  • 3 weeks later...
A little more progression photos:
had to order 28 shims from SuperTech to get to this point. But finally both intake and exhaust completely done. Waiting on the head gasket now. (It’s enroute). It’s a tight fit! :)E16C171C-2BBA-45B1-BB2A-9FA2E70D45BF.thumb.jpeg.88309d270b3969f74fe679960172c802.jpegB5779B50-9704-4C9C-ACF1-BAB365824A5E.thumb.jpeg.a0e85ba33b2c93596ea52d69aabf6fa3.jpegD270A4E3-BB28-419E-9780-ADABC53C2592.thumb.jpeg.d0a08a537d414127adb98e196cc54333.jpegFA7C87E8-09EB-4F2B-8A80-BFD6FC06AF3A.thumb.jpeg.a6a3e750f6373712bb1ddf391e8a8c37.jpeg
  • 1 year later...
I originally was shooting for 450 to the wheels and met that goal and some thanks to E85 😈. Low boost 15 PSI 513WHP and 357 TQ. Due to stock tranny high boost is stopping at 20Psi and 569WHP 396 ft lb TQ. I’m very happy with these numbers and cannot wait to learn this new beast.
  • Like 1
  • 3 years later...
Upgrade time. Been a long time coming, but I was able to get my GTR to a reputable builder in the States. List of upgrade parts below:
RB30 (Sourced from Australia)
PRP RB30 timing belt kit with all options
Nitto pistons
Nitto I beam rods
Nitto oil pump
King engine bearings
New RB26 Head (Grabbed during Heritage run)
Kelford 272 cams mild lift
Supertech intake and exhaust valves over sized
Nitto Head gasket
Greddy Oil Pan Sump
GKtech fan blade and adapter
Koyo Radiator
Borg Warner S362 SXE
6boost turbo manifold T4 divided
Turbosmart wastegate Pro-gate 50 lite
ID1340x injectors
Radium external surge tank
Walbro 450 fuel pumps x2
All Parts in hand and awaiting my turn in line at the shop!
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
