2001 Skyline R34 GTR - BNR34 RB26
KV2 Sparkling Silver, late model black interior
124500 kms
$85,000
Sadly looking for a new home for my much loved GTR - I need to finance a truck load of nappies for my new born's arse. It's been well cared for (the GTR, not the arse), with regular services and oil changes. It's been mildly modified to give a little extra power and better handling, but with reliability as the focus. Running at about 320kw at the hubs and never misses a beat. I've owned it since it was exported form Japan in 2007 and will provide a log and receipts for work done and mods.
Generally in good condition, but a few signs of wear and tear (a few stone chips and interior scuffs).
Plates are not included in the sale price, but can be negotiated separately.
PM me if you're interested.
Here’s a list of some of the modifications:
  • Nismo Z tune front bumper with lower lip and colour coded front spoiler
  • Nismo 320 kph gauge cluster
  • TEIN Flex Mono fully adjustable coil overs
  • TEIN Electronic Damping Force Controller
  • Nismo front lower control arms
  • Skylab torque split controller
  • Performance Friction two piece slotted front brake rotors,
  • DBA slotted rear rotors
  • Performance Friction pads all round
  • Goodridge braided brake lines
  • Kakimoto stainless exhaust
  • Blitz 80mm stainless downpipe
  • Garrett GT2860R-7 uprated turbos (N1 spec)
  • Intercooler polished hard pipes
  • HKS supersound sequential iv blow off valve (recirculating)
  • Tomei 600cc injectors
  • Nismo AFMs
  • Apexi air filters
  • Apexi Power FC ECU, boost controller and hand controller
  • GReddy oil cooler
  • ProAlloy 40mm core radiator
  • Samco silicone hoses
  • Polished washer tank
  • GTR embossed fuse box cover
  • TEIN gas bonnet struts
Edited by DJ Davey G
  • Like 1
https://www.sau.com.au/forums/topic/474235-2001-r34-gtr-for-sale-geelong-vic/
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
