So I just want to be cautious and be sure my oil return hose is up to the task with heat from the turbo and manifold
ive used a basic fitting/flange at the turbo with a screw on an fitting and vibrant brand braided hose which is rated to 300 degrees Fahrenheit down to another screw on fitting into the block
sound ok? Or Should I consider extending the return fitting in solid pipe 6 inches away from the turbo then the braided fitting?
It’s a 6 boost 3076 rb25 setup
https://www.sau.com.au/forums/topic/474248-turbo-oil-return-hose-setup/
