Wrighty Posted June 10, 2018 Share Posted June 10, 2018 Hey gurus. I have a bit of an issue.. s1 R33 Gts25t. Stock RB25DET . Apparently has : a hypergear turbo, EBay 50mms external gate with a screamer , boost controller, fuel pressure regulator, 3" exhaust and a big fmic and a forward facing plenum. Now the issue is it's running really rich and fuel economy is completely stuffed. The bov has been removed and the pipes been routed to the back of the intake manifold. I have changed my Ecu and maf, and it's still the same. I can unplug my tps and the car drives and.Runs normal, but if I unplug the maf the car stalls. Also if i squeeze the bov hose closed the car stalls... and honestly I'm lost as to where to look now. Any help would be awesome thanks. Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/ Share on other sites More sharing options...
Ben C34 Posted June 11, 2018 Share Posted June 11, 2018 You need a tune not a random ecu Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877911 Share on other sites More sharing options...
GTSBoy Posted June 11, 2018 Share Posted June 11, 2018 That whole setup is completely f**ked up. The BOV return line routed to the back of the manifold is actually feeding the idle control valve. Which is why it stalls if you crimp it. You can't run a big turbo and altered fuel pressure etc etc against a stock R33 ECU. It will tell you to go f**k yourself by making you fill up at every servo you pass. This fits your description of your symptoms pretty well. See above post. Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877912 Share on other sites More sharing options...
Wrighty Posted June 11, 2018 Author Share Posted June 11, 2018 thats what i was leaning towards haha , but ive not had time to look into the issues any further since i got the car. wheres the idle control meant to connect to? would be able to keep the hypergear turbo and sort out the bov/idle control piping? Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877913 Share on other sites More sharing options...
GTSBoy Posted June 11, 2018 Share Posted June 11, 2018 The idle air control draws from the turbo inlet, via a combo of rubber and hardpipes that are attached to the original crossover inlet pipe arrangement. The butchered plenum means that all that is gone, so the butcher found a way. The BOV returns to the same place (turbo inlet, a separate port), so it's not incorrect for it to be hooked up the way that it is, just an ugly hack. If you want a BOV back, you will need to attach it to the cold side intercooler pipe just before the TB and return it to the turbo inlet. This is not strictly necessary - just depends on whether you like dose or like to have the inlet air bypass the turbo when on cruise (which is what it is actually for). The main issue is the ECU. Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877921 Share on other sites More sharing options...
Wrighty Posted June 11, 2018 Author Share Posted June 11, 2018 thanks for help everyone, im thinking ill have to get a new ecu. but i still dont know why the car runs without the tps Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877930 Share on other sites More sharing options...
Ben C34 Posted June 11, 2018 Share Posted June 11, 2018 54 minutes ago, Wrighty said: thanks for help everyone, im thinking ill have to get a new ecu. but i still dont know why the car runs without the tps Because the tps isn't a very important sensor for how 99. 9% of cars run Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877935 Share on other sites More sharing options...
KiwiRS4T Posted June 11, 2018 Share Posted June 11, 2018 Original owner has wasted money on a FFP and a fuel regulator when what he NEEDED was bigger injectors and a tunable ecu...either a Link, adaptronic etc or for less money and a little investigation a Nistune set up. Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877943 Share on other sites More sharing options...
Wrighty Posted June 11, 2018 Author Share Posted June 11, 2018 upon closer inspection of that hos. it goes to the idle control... and is made like this...... Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877946 Share on other sites More sharing options...
GTSBoy Posted June 11, 2018 Share Posted June 11, 2018 That was evident from the 1st photo of the 1st post. Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7877988 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 11, 2018 Share Posted June 11, 2018 I have an Adaptronic Select Plug in ECU for sale. Install this, piss off your AFM and pay a tuner. Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7878006 Share on other sites More sharing options...
Wrighty Posted July 16, 2018 Author Share Posted July 16, 2018 been meaning to get this video for a while but had to rewire and relocate the gauges , video-1531725824.mp4 Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7881114 Share on other sites More sharing options...
Wrighty Posted February 17, 2019 Author Share Posted February 17, 2019 fixed the IACV hose that was butchered by previous owner, also have worked out it just needs an ecu and a tune to sort the other issues out, has new coils and plugs now as well Link to comment https://www.sau.com.au/forums/topic/474252-s1-r33-running-rich-and-some-other-funky-stuff/#findComment-7898601 Share on other sites More sharing options...
