Hey guys,
Ive got a kit id like to install on my 33. I have a genuine GTR spoiler and Skirts, with a GTR rep front bar but with genuine Gtr front indicators.
The skirts and spoiler are easy enough to install, but because ive got genuine parts, Im going to need someone who is familiar enough with these to preferably wire up the middle brake light for the spoiler, and correctly wire up the front indicators to my S2 Gtst indicator connectors.
So ideally for the sake of ease id like one place who would be able to not only fit all the items but wire them up correctly as well. Does anyone have any recommendations in Melbourne? Preferably western suburbs/Geelong area.. Or if anyone is super familiar with this stuff, id be more than happy to shout a couple of slabs/bottles/whatever your poison is for the time.
Or if its super simple a few pointers to get the job done
Thanks guys!
https://www.sau.com.au/forums/topic/474268-r33-bodykit-install-questions/
  • 2 months later...
Hey mate, although I'm always a fan of using factory or genuine parts as they fit better, but I appreciate sometimes you have no choice and go for replica items.
Anyway, for these kind of custom bodykit stuff I suggest you contact Freddy at Topstage Composite Designs: http://topstage.com
He can customise anything into awesome looking bodywork. He did a widebody conversion on my R33 GTR a while back and it's been years and the thing is still looking immaculate today.
Cheers,
Alex
5 hours ago, niZmO_Man said:
I think Topstage is overkill in this scenario :P
BTW you got any photos of the widebody R33?
Perhaps...but the OP sounded so serious so I gave him the best option.
Will post photos after I follow your advice on how to give it a good clean! ?
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
