Hi all,
I've finally got a brand new Nismo combination cluster for R34 GTT.
- Did anyone manage to transfer odometer readings from the old cluster onto the new one?
- Does anyone know a workshop in Sydney area that can do the job?
- Is it possible to register odometer change with RMS (RTA) without transferring the odometer readings from the old cluster onto the new one?
 All help is appreciated.
  • Like 1
Not legal to alter an odo reading, regardless of which direction you need to alter it.  Also, RMS would not care one shit how far the car has gone, whether real or resulting from speedo/odo swap.
Because you are putting in a brand new one with zero clicks on it, just take a photo of your old odo reading next to your phone showing the date and/or a newspaper showing the date that you do the swap.  That should be enough proof for anyone later that the kays you claim are true.
  • 3 months later...
My understanding is that it is illegal to change the distance the car has travelled, not change the new clusters reading to match the car. I transferred mine accross to the nismo cluster and took photographs of both reading the same. I checked here in NZ before doing it and was told I can do it that way.
  • 1 year later...
Hello,
I'm in the same situation; I bought a new nismo r34 cluster to fit on my R34 gtr
Could anyone give me some info to adapt the mileage ?
Otherwise if the chip where the mileage is stored is the same then I will do some soldering job...
Best regards
Edited by bigboss59400
You need a 93c56 eprom programmer they cost about $15 on AliExpress and I used software called Ponyprog2000 which is free to download. De-solder the chip from your old cluster. Read the information from the old cluster, it will look like this:Capture.PNG.7cf0c1fe11f7088b0e98b02091bf7bb4.PNG
The hexadecimal code in the red boxes is your mileage. Copy it to the eprom of your new cluster.20160622_193812.thumb.jpg.df4ef8141af2a2fb9cf14d8a2de72df2.jpg
Your car now shows the true mileage it has travelled. Take photos of the mileage of both clusters and also the clusters side by side as evidence that the mileage has been transferred. This picture is of a GTT cluster but I can confirm it is exactly the same for a GTR.
I have not tried to do a straight swap of eproms and when comparing between the old and new eprom you will see a lot of differences in the Hexadecimal code. This way you are only transferring your mileage.
Edited by NZ-GTT
  • Like 2
  • 3 weeks later...
hello
how To remove the cluster board ?
I removed all the screws however there is something which is blocking in the speedometer area
do I need to unclip the transparent front, unscrew the 2 screws which holds the speedometer and also remove the needle?
or do I need to unclip the black plastic (and so the front transparent plastic which is clip on the black part)?
best regards
Definitely do not remove needles and dial faces. You must remove all the screws on the circuit board including the ones holding the gauges and it should lift off the back of the cluster. You can disassemble it like in the picture but I found it was not necessary to remove the front covers on both the GTT and GTR  clusters.
  • Like 1
well I try again without dissasembling the front but for a R34 nismo gtr cluster it's not possible
I mean the speedometer part is blocking in some way...
So I will remove the front cover like you have done on the picture in fact
Thanks for your help
Yes I removed all the screws...the speedometer part is still blocking in some way; hard to explain without a video.
Yes I noticed the DIP package of the eeprom however since it's on the other side I can't determined the exact part number and thus the interface of it (SPI or 3 wire) and the memory organisation.
Anyway I will try to removed the front cover
thanks
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
