Alrighty gang, up for sale are my set of BBS LM's in 18x9 with the faces reversed for a (estimated) +5 offset. Perfect fitment on an R32 GTR. Will also suit a whole range of 5x114.3 cars.
I spent far too many hours getting these up to scratch polishing and flipping the faces (done correctly, loctite'd bolts and torqued to 30 n.m) so my loss (of time) is your gain.
Two wheels have some rash on two wheels, two are fine.
Tyres have almost full tread, but are very old. one tyre has a little chuck out the middle.
Last pic is fitment on a 32R.
Located SE Melb
Please pm me or text on 0424four90187 for any more info or questions. Wont reply to texts tonight as I'm at uni cramming for exams with no service inside the buildings so pm's preferred.
IMG_0704.jpgIMG_0707.jpgIMG_0691.jpgIMG_0683.jpgIMG_0698.jpgIMG_0687.jpgIMG_0699.jpgIMG_0151.jpgIMG_0084.jpg
Edited by Hardwork
forgot tags
https://www.sau.com.au/forums/topic/474274-gtr-bitsr32-bits/
Hey guys, bought this couple weeks ago but is no longer required.
Used, but reusable and comes with brand new clutch disks. Havent opened it since I recieved it.
Includes everything but flywheel bolts.
easily the most street friendly twinplate, drives like stock and is rated for 544kw.
model number: 3002A-RR593-C
Price is $1400, $170 less than what paid, and almost half the price of brand new.
Located SE melb. Please pm if interested.
Edited by Hardwork
forgot tags
Hey guys, trying to offload some bits to fund the new car.
up for grabs are;
Invidia catback 85mm (3.35 inches) for a R32 GTR - $450
RB26 engine covers full set, suit respray/powder coat - $700
Rebuilt R33 GTR turbos with steel rear turbines and HKS actuators with less than 5000km use, minimal shaft play and stock dumps - $500
R32 Dash mat - brand new with packaging - $50
I also have two other threads running containing:
BBS LM's in 18 x 9.0 with reversed faces for a +5(ish) offset, perfect for a 32R - $2800
Nismo Coppermix Competition Twin plate Clutch (PUSH TYPE) - $1400
So check those out if you are interested.
Please pm me for more photos and details.
Located SE Melb
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
