I’m planning my RB28 build since the engine now isn’t at the condition I want it to be at.
I will only use this car mostly for street and occasionally track days, therefore I want it to be responsive and stealth. My target is around 700whp .
Here is my wish list,
N1 Block
Borg Warner EFR 8374 1.05a/r hotside
Garage Whifbitz T4 Twin wastegate Twin Scroll Manifold
Twin Turbosmart Compgate 40mm external Wastegates
NITTO's RB26DETT 2.8Ltr Stroker Kit
Tomei 1.2mm Headgasket
Tomei Oil Pump
King Bearings
ARP Custom Age 625 Plus Head Stuts
Tomei Procam 260Degree 10.8mm Lift Intake
Tomei Procam 270Degree 10.8mm Lift Exhaust
Tomei Adjustable Cam Wheel
Tomei Type B Valve Springs
Tomei Type B Titanium Retainers
Tomei Bronze Valve Guides
Twin Walbro 450 Fuel Pump with Frenchys Performance Garage Twin Pump In-Tank Fuel System Kit
Earl’s Pro-Lite Ultra Hose -8 AN Feed & -6 AN Return Fuel Line
Plazmaman Fuel Rail
Fuelab Fuel Pressure Regulator
ASNU 1400cc 14 Holes Injectors
Ross Performance Crank Cam Trigger Kit
Haltech Platinum Pro Plug-in ECU
Greddy/Trust Intercooler
Greddy/Trust Radiator
ATS Twin Plate Carbon Clutch
Tomei EXPREME Ti Exhaust
Edited by etang789
Don't get Tomei valve springs, they're made out of a child's faeces, get BC or Supertech.
Don't get Procams, where's @Piggaz? Lol
Don't get a Ross trigger kit, get the Platinum Racing one.
Don't get the Platinum Pro, go Elite 2000 or 2500 (more features and inputs/outputs)
  • Like 1
I was thinking Ferrea valve springs and valves before.
Which cams would you suggest then?
I prefer the Ross over Platinum Racing because the sensor mount looks more stock and the wiring isn’t just sticking towards front of the car
I already have the Haltech Platinum Pro Plug-In for running a few years already.
1 hour ago, r32-25t said:
Cause it does everything better
not wrong but a 2.6 is still going to rip lol
23 minutes ago, Dale FZ1 said:
Indeed.  When 3.4 is a tried and tested option.
dont forget to add a billet block to the list
Yeah go with those springs OR BC or Supertech, the Tomei rubbish will give you nothing but issues when you start feeding in boost.
CAMS, give Kelford a call/e-mail and tell them what you're doing - I have no faith in those brappy Tomei cams, many have ended up putting in stock cams and/or switched to much lower duration cams so power band is much more usable.
Looks don't mean much, however the PRP kits use cherry sensors and can be fitted to any crank damper/pulley unlike the Ross kits.
Also if you decide to get the PRP you can't use the Haltech Platinum Pro as you can't unlock the trigger settings haha..
Lastly,  why Tomei pump when a Nitto pump can be had? Since you're going Nitto most things, might as well get a Nitto pump.
I noticed the word "Tomei" often repeated in that list as well as GReddy/TRUST way too many times ???
7 minutes ago, Leroy Peterson said:
Need Tomei for dat Speedhunters feature
http://www.speedhunters.com/2018/04/project-gt-r-gets-bigger-turbos/
LOL EVEN BIGGER twins, for that crisp lag
Refer back to :
http://www.speedhunters.com/2013/05/project-gtr-and-the-road-to-new-lungs/
  • Like 3
7 minutes ago, Dose Pipe Sutututu said:
"Since this first step is all about low-end torque and throttle response, I thought the HKS route would be the best option."
Riiiiiightttt :D
Yes it will but if you ever get to drive a 2.8 you’ll agree that it’s money well spent
if mine lets go the first thing on the shopping list will be a stroker kit
  • Like 1
Riiiiiightttt :D
He probably got discounted shit, just an advertising platform.
You can't go that fast in car parks anyway.
  • Haha 1
Budget Supercar went 9.92 with a stock bottom end. 2.8 or not, thats moving.
I never said it can’t be done but it doesn’t make it the best way to do it or make it a better street car
there’s a reason maatouks, crd and etc up the capacity, cause it’s better
no replacement for displacement :)
(inserts disclaimer about variable CR, cam timing, lift, TS, DI)
Yea I have emailed Kelford already waiting for their reply.
I guess I have to stick with Ross kit unless I switch ECU then
Yea been thinking either Tomei or Nitto for oil pump. Seems more people have used Tomei that’s all.
Reason for Tomei Exhaust is seems like they are the biggest size exhaust that’s off the shelf avaliable and decently priced. Local exhaust shop here is crap so custom make one isn’t an option, can’t accept those Workmanship on my car.
Reason for quite some Greddy/Trust parts is because I bought the car with everything Greddy/Trust installed and unless it’s critical I guess I will keep them.
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
